Squeeling hi pitch is usually the drum support roller above the heater. if you take the machine apart and turn all moving parts by hand you should be able to find the problem...if its a rumbling noise then it may be the blower wheel. UNPLUG FIRST..good luck :)
If you do repair it yourself.... do yourself a HUGE favor and either take a picture of the belt routing or draw a belt routing diagram BEFORE dis-assembly.
Prob. some failure of a bracket or loose inside... Have a local tecnician check it out. i think that ll be best cause i can't imagine that will be an easy fix.
clean clean clean everything, dont let it go to much longer or you will have a fire, and dont ignore this or you regret it... then tell me if it makes the noise
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
You Need to replace the drum Rollers. They cost around 10.00 Each online, 20.00 Each at your Dealer. Please Dont try to Put Oil on The Roller Shaft. It will come off and make its Way To Your Clothing. Martin Appliance Sells Specific Oil for the shaft for around 8.00. Thanks Sean
