Kyocera Km-6030 With Feed, Finisher, Bank, Print, Scan - 270k Copies Logo
A
Anonymous Posted on Mar 15, 2014
Error code c220 - Kyocera Km-6030 With Feed, Finisher, Bank, Print, Scan - 270k Copies
Konica Minolta Bizhub C220. It has error code C2557 constant paper jam and faint black and white printout
What is error code c2557 on Konica c220?
Check the toner bottle to ensure that it is feeding toner into the sub hopper unit under the bottle. Sometimes users will insert the bottle incorrectly and not lock it properly in place...the lever on the front of the toner hopper for that bottle is moved down to the left to remove and insert the bottle.
Dec 28, 2010
Error code C2557 - Konica Minolta - Copytechnet
1helpful
Konica Minolta bizhub C220 error code C-D010
disable hard discor try to do physicall format in service mode
Error code C4801
no such code for C220
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error code c-3421 in bizhub c220
Hi
The following site gives error codes for a wide range of printers and their user guides can be obtained as well.
Error Codes Konica Minolta bizhub C220 Code C3421
Your error comes up as follows:-
Code:- C3421
Description:- Fusing heaters trouble (Heating side)
• Detected temperature of the heating roller thermistor/C does not go up a given range of temperature even after a lapse of given period of time at warm up. • Detected temperature of the heating roller thermistor/C does not reach to a given temperature even after a lapse of given period of time after warm up is completed.
Remedy:- 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 6 Change PRCB. 7 Change DCPU.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Error Code C2152
Transfer belt code was it replaced properly?
2answers
Fusing heater trouble konica c220
You need to change the thermistor on the fuser unit.
Error code EA3226 when I try to scan to e mail on Konica Bizhub C220
this error code is not listed in any of the konica c220 books or on the konica minolta service tech internet site
1helpful
2answers
Mio c220 "Fatal error ..restarting"
try holding down the power button until it reboots
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
