SOURCE: panasonic KX-TGA236JXS gigarange phone is dial lock
panasonic KX-TGA236JXS give error dial lock
SOURCE: panasonic KX-FT73 dial lock
Press the menu key twice and enter the password. If you don't know it, key in menu#9000*550 start
SOURCE: panasonic KX-FT71 dial lock by gobuzer
needed to reset,
press menu,#9000*550 and start,is all.
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
SOURCE: changing all speed dial numbers
Speed dials reside in programming memory 001. You can change them from the maintenance console software, or an extension, usually on Jack #1, operator, or the manager's phone.
From the phone, (ext 101) press PROGRAM and dial **1234. If the display says SYS PGM then dial 001 and start with your first speed dial number (3 digit, 001-999). By stepping through the ENTER key, you will be able to find the existing numbers. A trunk access code must be the first part of a speed dial number. You probably see it as the first digit "9" in front of all your numbers.
Carl
