Check whether the 'panel lock' function has been set to 'On'. Refer its user manual for details. If it is set to "On' make it "Off'.
Gopakumar Gopalan Google
SOURCE: Remote's menu and input buttons, and television Input button not responding
well the problem sounds like it could be the IR sensor on the tv or somthing in that circut that is failing or the EPROM chip that controls : Vol up/down , Channel up/down , Power on/off ,Menu , Input selection , ect... is failing, thus this will trigger the protection circut to shut the tv down. this kind of a problem only gets worse and can dammage other components if not repaired soon so it will need testing to determine the exact cause
SOURCE: Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
SOURCE: The volume control does not work by remote control
Have you tryed unpluging the TV and pluging it back after 30 seconds?
SOURCE: Samsung le40r74bd problem
I just had this problem with my 3 year old 32" Samsung LCD. The volume would go up and down by itself, normally just constantly going up even when it reached 100%.
I thought it might have something to do with the volume buttons on the TV itself so seeing as it was out of warranty anyway I decided to unplug it and open it up.
I gave it a good clean and I disconnected the cable for the panel of buttons on the LCD itself (volume, menu, channel etc) seeing as I never use them anyway. I then put everything else back together and tested.
It seems to be working fine now. Previously (for the past 3 hours) ever time I turned it on the volume level would come on instantly and stay on until I turned the TV off. So I’m quietly confident the problem has been fixed. But I must admit it’s only been 10 minutes, so who knows, it might come back.
