Apple iPad (16 GB) WiFi Tablet PC Logo
g
glenys Posted on Mar 16, 2014
How di i delete photos from my i pad the photos are in sync with my pc
I have hundreds of photos in my i pad ,they have not been taken with the i pad how can i delete some of them i am now connected to my pc
Curlee Woods
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 16, 2014
Curlee Woods
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
50
Points
Go to your setting.
2helpful
5answers
How do I delete unwanted photos from my tablet?
Just open gallery, find "select" , do it then use the same 'button' to bring up a list of options. 'Delete' should be there.
3answers
Hi how do you delete pics transferred into ipad?
AnyTrans is an iOS content manager that allows you to transfer and manage your iPad, iPhone or iPod content. And you can also use it to delete selected or all photos from your iPad. delete-pics-transferred-into-ipad-mb2hin5dvim4cccemdykfxsm-4-0.png
I want to delete all the photos on my ipad but none on my computer. How do i do this?
First sync your iPad using iTunes and uncheck all the albums on your iTunes you have synced to your ipad. Once that is done you cans tally delete the pics ok your iPad. Hit select, then select all the photos you wish to delete, then delete. That should do it.
For or a complete clean, if your iPad is jailbroken use icleaner.
3answers
How do I clear up photo space on my iPad?
Plug it into your computer and open iTunes. Click "Photos" and follow the instructions to sync your photos. Then empty your library. If you don't want to sync with iTunes, you can also use your favorite camera importing app like "Image Capture" Just choose "Delete on Import" options and your iPad will be clear when finished.
4helpful
3answers
Delete photos from my apple ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to remove the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to remove from the iPad under the Sync Photos from heading.
5.If you want to remove all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
More detailed guide about how to delete photos from iPad.
www.iphone-mac.com/how-to-delete-photos-from-ipad-camera-roll.html
2helpful
6answers
How do you delete photos from ipad?
To delete photos in 1st generation ipad tap photos,tap photos again then tap photo you would like to remove.When in full mode trash can is available.
For 2nd generation and new ipad,tap photos then edit.Tap each photo to add check then tap delete to remove all checked at once.Please Rate
5helpful
4answers
How to delete photos from the Ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to delete the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
4.Uncheck all of the albums or folders that you want to delete from the iPad under the Sync Photos from heading.
5.If you want to delete all of the photos - uncheck the Sync Photos From heading
Done.
If it can't work, you can refer to the article about Delete photos from iPad.
Good Luck!
2helpful
How do I delete photos from I pad. I did not install these photos. They appear. I tried selecting them but the delete button is gray out.
you do not have to select the photo! when you open each photo at the bottom right there should be an option to delete (trash can) icon! If you click on that the picture is deleted. Also you can delete you can delete entire camera roll!
5helpful
4answers
How do I delete a photo on an IPad?
More info: How to delete a photo on an iPad
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
