I have disconnected all wires from the back of player, and it still turns off and says "s-protection". If I unplug it and plug it back in, it will work for about 30 seconds then goes off. Would that mean there is a short inside the unit itself?
But I disconnected all the speaker wires, and it still does it. What inside would need to be replaced?
thats great...thank u very much...it really works...
pls I'm experiencing the same problem, what would I do?
Hi, am experiencing same problem here how do I go about it nd I have disconnected the wire but still the same!!!. The most annoying thing is that I bought it online..
Here's what I did to fix the problem. I threw the expensive piece of junk away, and I vowed never to buy an LG product again.
hi am also experiencing the same thing
I experiencing this very same thing
How to fix s protection problem please.
That stands for speaker protection. Either you are playing the system too loudly, causing the amplifier or speakers to overheat, or there is a defective speaker or a short in the speaker wiring (where the two wires are touching each other).
it works...thanks
yes it works thansks kannnan from chennai
pls cannan cool can you give me the solution that worked for you on the 'S-Protection' issue
I am interested in a solution. Mine is the main board am I close?
Hello I'm from Trinidad and Tobago also an LG stereo is saying S Protec also and switch off for itself , sometime it's comes back on and switch off for itself again
Hi I am from Trinidad and Tobago my LG CM 4350 is saying S Proctec no sound what is my solution besides a repairman.
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
