Kodak EasyShare EX1011 Digital Picture Frame Logo
Posted on Jun 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The kodak easy share digital picture frame won't show my pictures
The only thing that will appear on the screen is My Frame and Settings. No matter what button I push on the remote, nothing happens. How do I get the pictures to start appearing on the screen?
Pania Lee
Level 3:
Genius:
  • Kodak Master 1,099 Answers
  • Posted on Oct 15, 2009
Pania Lee
Kodak Master
Level 3:
Genius:
Answers
1099
Questions
Helped
218828
Points
1986
Pls. check if there is any reaction when pressing the buttons onto the frame.
Check the batt within the remote.
Reset the frame.
If all fails:
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
1 Related Answer
  • 102366 Answers
  • Posted on Nov 20, 2010
SOURCE: Where can I get a manual for a Kodak Easy Share
Getting Started Guide:
http://support.en.kodak.com/app/answers/detail/a_id/18777/kw/sv811
User's Guide:
http://support.en.kodak.com/app/answers/detail/a_id/18780/kw/sv811
Where can I get a manual for a Kodak Easy Share digital picture frame - SV811?
User's Guide:
I have a kodak easy share photo frame and don't know how to transfer pictures from my computer to my photo frame
Make sure you have installed the Kodak digital display Software then you can just drag and drop the pic to your pc or vice versa
Images from memory stick will show on frame but
Try these steps: 1. Insert the card.
2. Tap on MENU.
3. Select PICTURES and tap on OK.
4. Highlight SD/MMC and hit OK.
5. Once you see the thumbnails of the pictures, tap on MENU again.
6. Scroll down to MULTI-SELECT and hit OK.
7. Tap on MENU and scroll down to SELECT ALL and hit OK.
8. Tap on MENU and scroll down to COPY and hit OK.
9. Highlight INTERNAL MEMORY and hit on OK.
1helpful
HOW DO I DOWN LOAD PICTURES FROM EASY SHARE PORGRAM TO PICTURE FRAME?
There is no internal memory in your frame. You can transferre them via the SD card onto the frame. But unfortunantly not irectly onto the frame without a SD card.
Contact KODAK:
Will Not View All Pictures In Photo Directory
Take the camera and tag the pictures and select all of them and tag/ favorite and protect and tag some more directories you can create. That will delay transfering the pictures but all of them will transfer to files.
Vitally
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
How can I display pictures in "random" order on my digital frame?
Go back to the Home screen and go to the Settings. Select Viewing Options and activate Suffle/Random.
Easy share sv811
1. Press MENU whenever pictures/videos are displayed (slide show, video, single picture).
2. Press ARROWS to highlight Select all, then press OK. A confirmation screen appears, then your picture display reappears. A check mark is displayed on all pictures/videos in your current location. 3. To remove all check marks, press MENU, highlight Select / Unselect all and press OK. 4. Highlight Unselect all and press OK. Also, you may get the manual at www.kodak.com/go/manuals
1helpful
2answers
Kodak easy share SV 811
I had the same problem. I use kodak easyshare software and load my pics on to that. Then put all the pics you want in the picture tray. Have your frame plugged into the computer with your usb cord. Then go up to File menu and drop down to "copy to". On my computer it is Folder "E" which is the drive the frame is connected to. Then pick from the Resize drop down menu " best for picture frame', then click copy. You will see the program loading all the pics to E drive. When done, unplug usb cord and you will see it loading on your pic frame. As easy as this is to do, I found it frustrating as well, but when it works, it is easy. Hope this helps
Top Kodak Photography Experts
Bill Eager
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Kodak Photography Expert? Answer questions, earn points and help others
