The black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
