Honestly, I tried netflix, and after two hours searching, I didn't find anything I wanted to watch. I cancelled my membership.
Netflix works in your computer. You need a good internet connection, and you watch movies and TV shows on your computer. You need speakers connected to your computer to hear the sound....
the problem could either be the port or your headphones. try to check if your headphones are working on a different computer; if they are, try hooking a set of external speakers on the audio port of your g430. if you don't hear any sound from the external speakers, then the problem is with the port itself. check if your computer is within warranty; if it is, contact lenovo technical support
does the wii see the router do you have a laptop to make sure its sending a signal try this dis connect everything plug in the modem let it symc up by it self then plug in the router and hook up the cat 5 cable to the router the try to sync the connection with the wii by searching for the router it helps to name your router first with a laptop but that should work if not let me know iam a cable tech with a few tricks
You have just about answered your own problem. If you can hear sound on other computers and also on TV, then the camera is sending out sound. You should be downloading the video to your laptop with a USB cable. Make sure that you use the same cable on your laptop that you used to download on other computers. In the worst case you could get a card reader with USB and remove your memory chip from the camera and load it into the Card reader. That should solve the sound loss. I have also seen a laptop that would make sound when windows opened up but would not play a music CD. You might want to test your laptop with a music cd before you buy anything!
only the hd channels get great surround sound. if your tv has an optical audio out and your surround has the optical in input. then i suggest buying a fiber optic wire for the audio you'll hear a big differance. just hope that the audio stays in sync unlike my cheap *** koss system
