Filter status light is red and stays red after resetting following 2 water filter changes.
SOURCE: I have a Frigidaire Model FRS26ZSH need water filter instruction
Filter Status Press and Hold five seconds to reset
light. (This light will tell you when to replace the
water filter.)
press the button to the right of water filter to release filter...
SOURCE: Water Filter Indicator Light on Maytag side by side
Hold light and lock until change filter light blinks
SOURCE: how do you reset the change filter light , have replaced filter
Question:
I have replaced filter but how do you reset change filter light?
Have replaced the filter. The light is still red.
Answer:
After changing the water filter, press Cubed and Crushed buttons simultaneously and hold 3 seconds.
SOURCE: how can I change the water filter on a frigidaire fridge
Hi, The filter is in the upper right hand corner of the fresh food section. Turn the filter cup counter clockwise to remove it. There will be a filter cartridge in the cup that you replace.
Please let me know if this has been helpfull or if I can assist you further
Thanks
Vic
SOURCE: How do I reset the 'change water filter' light~the
Hold the botton on each side of the light in , until they start flashing .
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
