Two possiblities
1)not enough ink for the saturation of the media
2) media is not correctly saturated by the ink
sounds like the same issue- let me explain
your image may be purposely printed light because of 'ink save printing'( driver cuts down reqired ink levels to give a draft print.)
or your problem may lie with the paper type itself,
firstly have the machine print off its internal demo page ( read user manual to find how to print)
this print being held by the printer cannot be affected by external controllers, if the demo page looks nice aand even and strong in colour then your issue is software related and you should have a look at how the pc is handling these documents before they get to the printer.
if the demo image is light then you have a problem inside the printer
if it is the latter please re-post as internal demo page printing light in colour
Clean print heads remove ink cartridge and take a paper towel wet it and clean the cartridge off of there is dry ink on it. Your ink cartridge could be almost empty. Ink cartridges dry out fast. If you do not use ur printer often the ink drys out.
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
MAKE SURE YOU ARE NOT PRINTING IN THE ECO MODE. THE CARTRIDGE MIGHT BE EMPTY BUT APPEAR TO HAVE INK IN THEM. REPLACE THE CARTRIDGES AND THINGS WILL GO FINE. REGARDS.
PLZ. DON'T FORGET TO RATE
You said you replaced the cartridges. Were they Genuine Brothers' Cartridges?
My Brother MFC-240C, does not like Generic Printer Cartridges.That sounds like your problem.Also I had with Brother's was problem with Color. Color that should be Yellow, will turn out Green, or Blue Green, etc.The Generic Cartridges, also printed lines thru the words. That's what the Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY, or Take them to have them filled.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for the PRINTERS.
This is the only advice I can give you. If you find this helpful, pls rate me.
