Hannspree SN10T1 101 Tablet Logo
A
Anonymous Posted on Mar 16, 2014
Reset button Can't find reset button
Kathy M
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 28, 2014
Kathy M
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
338
Points
1. Go to settings
2. Scroll down to Backup & Reset.
3.Go to Personal Data
4. Choose Factory data reset.
Be aware that you will lose all unsaved settings. I've tried doing it numerous times to try to get the non working camera to reset and also to get the G-sensor to work. Not fixed doing this.
Nextbook 8P won't reset. I have tried troubleshooting instructions with no result
you are having trouble resetting your Nextbook 8P. Here are a few steps you can try to reset your device:
  1. Soft Reset: Hold down the Power button until the device turns off, then turn it back on.
  2. Factory Reset using the Settings: Go to "Settings," then "Backup & reset," and finally "Factory data reset." Confirm the action and wait for the reset to complete.
  3. Factory Reset using Hardware Buttons: If you are unable to access the settings menu, you can try resetting the device using hardware buttons. To do this, you will need to follow these steps:
  • Power off the device
  • Press and hold the Volume Up button and the Power button
  • Release the buttons when the Nextbook logo appears
  • Press the Volume Down button to navigate to "wipe data/factory reset" and press the Power button to select it
  • Confirm the action by pressing the Volume Down button to select "Yes" and the Power button to confirm.
If none of these steps work, the device may have a hardware issue and it may be necessary to contact the manufacturer or a professional repair service for further assistance.
How do you reset a digital 2 tablet without volume buttons
If your Digital 2 tablet doesn't have volume buttons, you can still perform a factory reset using the following steps:
  1. Power off your tablet: Hold down the power button until your tablet shuts off completely.
  2. Hold down the power and home button: Once your tablet is powered off, hold down the power button and the home button simultaneously. The home button is the physical button located on the front of your tablet, usually below the screen.
  3. Wait for the recovery screen to appear: Keep holding down the power and home button until the recovery screen appears. This may take a few seconds.
  4. Navigate the recovery menu: Once you see the recovery menu, use the touch screen to navigate the options. Select "Wipe data/factory reset" using the volume buttons on the screen.
  5. Confirm the reset: Use the touch screen to select "Yes - erase all user data" and confirm that you want to perform the factory reset.
  6. Wait for the reset to complete: Once you confirm the reset, your tablet will erase all user data and reset to its original settings. This may take several minutes to complete.
  7. Restart your tablet: Once the reset is complete, your tablet will automatically restart. You'll need to go through the initial setup process again, like you did when you first got the tablet.
Please note that a factory reset will erase all of your data, including apps, contacts, and media. Be sure to back up any important data before performing a factory reset.
1helpful
How do I factory or hard reset my digiland model No. Dl8006 tablet
hard reset
hold down the power button and the volume down button at the same time till the chinese writing comes on
then go down with the volume down button to the 6 menu = 3rd from bottom press the power button to ok it
then it will reset
if its in english do the first bit hold down power button and volume down button at the same time till the android man with writing comes on
go down to wipe data withe the volume down button highlight that press the power button to ok it
then go down to yes with the volume down button highlight yes press power button to ok it then it will reset
then if it goes back to the writing go to reboot highlight that press power button to ok it
factory reset settings go down to back up and reset click on
go to reset
then it will reset
HOW TO RE-SET PRESTIGE ELITE 8Q ANDROID TABLET
hard reset
turn off tablet
press and hold power button and down volume button at the same time release the button when you see visual land then hold the volume up button
you will see the android man with writing go down with the volume down button to wipe data highlight wipe data press power button to ok it
then the writing will come back on highlight reboot press power button to ok it
the tablet will reset
Factory reset
go to setting click settings
go down to back up/factory reset click on that
then press reset everything
Reset my proscan notebook plt1035
I cannot find that model number is it a tablet or is it running windows?
if tablet
How to reset Proscan PLT722 when you forgot your password or unlock pattern. How to remove unlock pattern on your Proscan PLT722 android tablet
To reset this tablet is a little bit tricky, because there are no physical Volume keys on the device, but we have a "hidden" RESET hole (on the side of the tablet) and using this we can easily do a factory reset on the tablet to remove the password and get access to it.
Using the Hard Reset (Factory Reset)
If you want to restore your Proscan Android tablet to its original condition, use a Hard Reset (Factory Reset) to initialize it.
1. Turn the power off.
2. Find the tiniest RESET hole on the side of the tablet next to the micro USB charger port and use a paper clip or similar tool to click it, press gently the RESET button in the hole. While you are pressing the reset button press and hold the Power button also until the Proscan logo comes up and the Android robot is displaying on the screen. (Note this is not the RESET hole on the back of the device.)
3. Release the Power and the reset button.
4. To get into the Android recovery menu you have to click it push it down again the tiny little RESET button in the hole and the POWER button together. Keep pushing the two buttons until the recovery menu displayed.
5. To highlight the options use the paper clip and press the RESET button to move down the highlighter bar until you get to Wipe data / Factory Reset. Press the POWER key to get in the next menu.
6. Move the bar again using the reset button and highlight Yes -- delete all data and press the POWER button.
WARNING
If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to backup any important data before performing a Hard Reset.
Proscan PLT722 soft reset or restart the device when it is frozen If device is hanging, use a small pin or paper clip to press Reset hole on the back of the device, it will forced shut down and the device will power on again.
Proscan PLT722 factory reset from the menu Factory data reset - Reset your settings to the factory default values and delete all your data. If you reset the tablet this way, you are prompted to re-enter the same information as when you first started your Android tablet.
Go to Settings > Backup & reset > Factory data reset > Reset Tablet and confirm
All data will be deleted!
Check the software version on your tablet: Settings > About tablet> System updates > Check now.
NOTE: Your personal data from internal phone storage - including information about your Google account and any other accounts, your system/application data and settings, any downloaded applications and your DRM licence - might be lost in the process of updating your phone's software. Therefore, it is always recommended to backup your personal data before updating your phone's software.
I forgot my password for my trio stealth g5 7 can u help me reset it or something?
I Forgot My Password To Unlock To My Tablet? Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
  2. Tap on Backup and Reset on the left hand column.
  3. Tap on Factory Data Reset on right hand side.
  4. Tap on Erase SD Card. (optional)
  5. Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset
  6. Tap Power button to select.
  7. Use Volume - button to scroll to Yes.
  8. Tap Power button to select.
  9. Tap Power button to select Reboot System Now.
7helpful
3answers
How to unlock my coby
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
I keep getting an error message everytime i turn it on and when i try to look at my pictures in my gallery.. it says something like andriod.proces..media isnt working and also it will knock me off the...
You did a soft reset, try master reset: Here is a step-by-step procedure on how-to perform a factory reset when the unlock pattern code has been forgotten:
*******This procedure will delete all items (file's) and entries on the MID7015******
3helpful
How can i reset my coby tablet
3helpful
3answers
Where is the reset button in this product? The first thing the manual tells us to do is to put batteries & reset the machine by pressing the ''reset'' button. I have studied the buttons some 10 times but...
On the back of the viewsonic tablet pc or at least on the V1100 the is a small pinhole type openining. Here you may need something as small as a needle to depress the button. It is located 3/4ths of the way down on the back of the pc.
Top Hannspree Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Hannspree Tablet and eReader Expert? Answer questions, earn points and help others
