Televison & Video Logo
M
Mark Posted on Mar 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dp52449 firmware update
Is there a way to update firmware on this television, Sanyo DP52449
  • Mike Ah Fook Mar 17, 2014
    Hi Mark , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Mark
    Mark Mar 18, 2014
    sound is not in sync with picture
Mike Ah Fook
Level 2:
New Friend:
  • Expert 72 Answers
  • Posted on Mar 18, 2014
Mike Ah Fook
Expert
Level 2:
New Friend:
Answers
72
Questions
0
Helped
7987
Points
122
I ask one of the technicians you need to go though your sync setting againg but for firmware update, you cant update it.
thanks
1helpful
How can I update my Sanyo Tv,It is not a smart tv
Upgrade to newest version firmware on you device, sanyo tv custom firmware update you current version firmware to latest version, download newest firmware.
Download new release software and update firmware last version
  • Last update version: 02.01.2020
  • Country: All
  • Download Size: 134 MB
  • Language pack: English, Chinese
  • Version: 5.1.11
Download and update firmware for products: sanyo fwbp505f firmware update, sanyo blu ray firmware update, sanyo android tv firmware update, sanyo projector firmware update, sanyo fw55d25f firmware update.
How to check power supply
You can use this LCD Digital Ohm VOLT Meter AC DC Voltmeter Multimeter
Or this Digital Amp Ohm Volt Meter Ac Dc Voltmeter Multimeter
or any other similar device..
Line on the right side of my tv screen DP52449.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
How to update firmware on Sanyo DP52848 ? There
If you wish to get more details about firmware update, check this link. It has firmware update procedure to many model TVs, with illustrations. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
1helpful
Model DP52449 does it have PIP ?
No. This set has no PIP option. If you want its manual, send your email address to me, and get back a copy or it by return mail.
Sanyo dp52449-01 no picture, has sound, screen has faint brightness
The described may lead many to point to backlight inverters however it is extremely uncommon for backlight to work in a way that would produce "faint" light.
it is a whole lot more likely that backlight is functioning properly, but the display in front of it is all shut and not functioning, i.e. all light filters are closed and not opening.
This would point to either the T-CON board or the main board or, at worst, the LCD itself, which is however less likely.
May be something as simple as a bad connection of a cable on the LDVS cable - we've seen that happen once or twice.
We've also seen exactly that happen due to a problem on the main board, but the circumstances were such that it's hardly the same issue.
In any case , if you want the main board tested and possibly repaired you can use this:
http://www.coppelltvrepair.com/p/59/sanyo-dp52449-p52449-01-main-board-n7ke-repair-service
2answers
2helpful
3answers
Sanyo DP52449, tv getting power but no display
When DP52449 (chassis 01 - that is important!) does not power on and the front LED flashes every 15-20 seconds you have a faulty main board, which you need to replace or get serviced.
We presently do not offer replacement boards, but we do offer repair services for them at
You may also be curious to read the article we wrote back in July 2012 on a problem that sounds exactly like yours and which lead to the service offerring:
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
Hope this helps!
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
