Kyocera mita 5035 eror code c0320
SOURCE: kyocera mita 5035 code 6400
Zero-crossing signal problem • The main PCB does not detect the zero-crossing signal (Z CROSS SIG) for the time specified below. Causes Poor contact in the connector terminals. - Check the connection of connectors YC1-3 on the main PCB and YC2-6 on the power source PCB, and the continuity across the connector terminals. Repair or replace if necessary. Defective power source PCB. - Check if the zero-crossing signal is output from YC2-6 on the power source PCB. If not, replace the power source PCB. Defective main PCB. - Replace the main PCB if C6400 is detected while YC2-6 on the power source PCB outputs the zero-crossing signal.
SOURCE: My Kyocera KM-5035 receive error
Hello, This error C4200 indicates a problem with the main Laser Scanner Unit. The laser scanner functions to image onto the drum in the copier. It scans at a high rate of spped, the error indicates it is in trouble.
The Laser scanner would need to be changed.
It is also possible the main PCB is failing (remote chance)
Find a Kyocera Repair Facilty.
SOURCE: i want to download kyocera mita driver 5035
http://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.KM5035._.EN.html
