The problem does not seem to happen in any specific app or for any reason. When you start the iPad it works perfectly then after about 30 mins the picture shows animation but none of the buttons work. Only way to restart it is to force start it. This is not workable if you are in the middle of a document.
Follow the steps below so we can get that iPad back up and running.
Your first two solutions are:
Restore the iPad
If neither of these two options fixes your unresponsive iPad then you will need to restore the iPad to its factory settings.
SOURCE: Some apps that used to work, don't anymore
There is a problem with the iTouch itself. Go to the nearest Apple store and tell them what's wrong, and hopefully the can fix it.
Hope it helps~
SOURCE: problems transfering apps from iphone to Ipade
You are able to use any appstore app with the iPad. Make sure your iPad is listed as a connected device in the left side bar of iTunes. Check your sync settings to make sure they're set to sync with your iPad and if needed restore your iPad using the restore button and try to sync again.
To make an application fullscreeen tap the small "2x" button in the bottom corner of your iPad. This will upscale the app to fullscreen.
Hope this helps, if you found this helpful please leave some feedback. Thanks.
SOURCE: Volumne no longer working for all apps on the IPAD
In the latest software update, the orientation lock switch was changed into a mute switch. Do you have it on mute? This could well be the problem! Try flicking it and see if you can adjust the volume then.
You can still lock the orientation in the latest software by double-tapping the home button, flicking right and tapping the lock button. In future versions of iOS, you will be able to choose what the switch does to suit your preference.
Hope that helped!
SOURCE: Unable to access some apps installed on my iPad because no icon shows up on the iPad for these apps
When you exceed your allowed pages for apps,they will still install,but app cannot be created for lack of pages.You can get more room by grouping similar apps into 1 folder to make space.You can also use search function to fill any app installed.Scroll all pages to right until keyboard appears,then type name of app,it will appear in dropdown list.
Please Rate
Possibly one app is locking up networking... My gf had this problem after ios update to 8.0. It turned out facebook app became messed up. I uninstalked facebook and everything was great. Reinstalled facebook and it worked fine after that...In fact her whole ipad got faster... IOS updates are becoming painful...
