Vizio SV470M LCD TV Logo
A
Anonymous Posted on Mar 18, 2014
No audio audio go out for long periods of time
After a period of time on the phone,sound breaks up
This could be a fail with the speaker in the phone (water damage is a favourite), electronic faults (The Analogue to digital converter is failing), or simply a lack of signal strength in your area causing the signal to fail. Remember mobile phones are actually a radio transceiver and that all the problems that affect them also affects mobile phones (Crackly signal loss of signal bad audio etc etc).
32 inch sony trinitron wega
It will most probably need an overhual of the power supply
Why does my receiver start stop producing audio output half an hour after turning it on?
Most likely is an intermittent solder connection opening up as set warms up.
May 09, 2012 • B&K CT600
2helpful
Audio fades then stops after a few minutes of power
I had this problem on a sharp flatscreen lcd. the audio output i.c. was a surface mount chip-had to change complete signal board assembly,
The microphone cuts out
Normal 0 Go to "TOOLS", click on "OPTIONS," Then go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correctly chosen. Then "make a free test call." Wait till the voice tells you to record. Then when finished talking wait for the test persons voice to insure your audio transmission is working. Then go back to options and test your video settings. Click on Video Settings and proceed to set up you video camera. Also, you can visit this site for additional information to setup video.
http://www.skype.com/help/guides/video/
Hope this helps. Bud
Receiver switches modes after a period of time
The actual switching is done by an electronic microprocessor. This electronic processor is most likely faulty by now, and needs to be replaced. Repair costs for this are expensive enough that buying a new receiver might be the best logical action, as a new comparable unit might cost only slightly more than the needed repair costs for the SA HE 200. Good luck.
Screen zipped down to dot of light in center and went blank. No audio either
the deflection circuit shut down and i hope it didn't burn the crt's .
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
