Had same problem. Press and hold C (mode) until the display flashes. Then press C again (without releasing) to get to time. Press "Select" to move from sec, min, hours, days, etc. Press advance to go change the actual time.
these directions work
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
if you change the following:
C=C Mode
A=Select
B=Advance
Normal Time Setting
5.1 In Normal Display, hold C-Button for more three seconds
and then push C-Button once. Tuesday flag and seconds
digits will flash. Push B-Button once to reset the second
to zero.
5.2 Push of A-Button once: Minute digits flash and advance by
depression of B-Button
5.3 Push of A-Button once again: Hour digits flash and advance as above.
5.4 Push of A-Button once again: Month, digits flash and advance as above
5.5 Push of A-Button once again: Date digits flash and advance as above
5.6 Push of A-Button once again: Flag of weekday flash and advance as above
5.7 If push of C-Button during any changing time, Normal Display will be
appeared
