Our KDS-60A2000 was on and operating normally, then heard popping noise - then screen went black and no sound. Checked lamp and it has blown, but cannot get any sound when I power the TV on again. The green power light flashes continually for several moments after powering on, then it stops flashing and red Lamp light begins flashing - but still no sound. I know I need to order a new lamp, but how should I address the no sound issue? Thanks
SOURCE: i heard a pop and screen wet black. red lamp
Lamp inside TV is broken and requires replacement. Pop sound was its breaking sound.
Lamp replacement procedure is written in user manual, pretty easy.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheap lamp.
Let me know if you need to download user manual copy.
Thanks.
Testimonial: "thanks for sll your help!"
SOURCE: My Green power LED is flashing continuously.. no
Ur power supply board is dead,need a new one.
SOURCE: Suddenly turned off without warning Sony KDS-50A2000
Symptom shows tv needs lamp replacement as existing lamp is reaching to end of its working life and causing that problem.
If you have not replaced lamp in last 2-3 years, replace it to fix the tv issue. I can explain why tv shuts down itself and turns back on.
I do not agree with info provided about bulged capacitors in power supply so please do not take off back of tv unnecessarily.
Lamp replacement procedure would be written in user manual and let me know if you need to download manual copy.
Thanks.
SOURCE: sony kds-60a2000 power light flashes 5 times, no picture
5 flashes - Lamp Driver - (lamp driver faulty)
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
SD TECH
Thank you for your quick trouble-shooting response. I'll order a bulb and if this doesn't solve the sound issue, should I replace the Main Unit (Sony item # 1-870-331-12)?
