Question about Smith Corona Wordsmith 100 Typewriter
Daisy wheel typing random
Typing only vertical lines
  • 482 Answers
Most of the time that is caused by a broken print wheel try another one.
Posted on Jan 17, 2018
6ya staff
SOURCE:
Why did my lowercase o all of a sudden change to print 2 vertical lines on my IBM wheelwriter 5
More thatn likely you have a broken petal on your print wheel. Need a new daisy wheel.
Nov 16, 2017 | IBM Office Equipment & Supplies
The nakajima ae610 types two vertical lines instead of letters
The print hammer is striking between the letters. Two thing
you may have a petal, letter broken off. If its the same letter every time usually thats it, need new daisy wheel.
Or Homing is off when the wheel turns hammer hits between letters. Needs repair.
Or
Daisy wheel petals are bent.
Dec 12, 2016 | Nakajima Office Equipment & Supplies
My cx 90 brother professional typewriter does not type the correct letter when done manally
First I would remove and inspect the daisy wheel for bent spokes. If that looks ok there may be a problem with the selection plate assembly, but it would take a technician to figure that out. Just make sure you turn the machine off/on if you removed the daisy wheel so it can re-initialize and find the home position of the daisy wheel. good luck.
Sep 06, 2012 | Office Equipment & Supplies
When typing with my brother gx-6750 it types weird lingo is the type set messed up or can I reset them?
Your daisy wheel letters are bended not straight.
Switchoff just remove your daisy wheel & remove the daisy wheel from its cover & see all the letters should be straight.If any of them is bended jst make them straight by your fingers dont press too hard & then fix the daisy wheel back & switch on typewriter.
Jul 20, 2010 | Brother ML-100 Typewriter
TYPING EVERY CHARACTER BUT WHAT I'M ACTAULLY TYPING-
Check for KBII and PS (ketboard II , Proportional space) or any bthing interfearing with the printwheel.
DickyO
Apr 06, 2010 | Brother SX-4000 Typewriter
How do I reset the Daisy wheel?
Turn the typewriter off. There is a release lever for the daisy wheel. it will rock backwards. take out the daisy wheel. Turn on the unit..the daisy wheel motor spins to the home position. inset the daisy wheel carrier, snap the carrier closed. You should be in home position. if not turn it offf and on again, the daisy wheel should spin. if not do the proceedure over again.
Happy typing
Dec 18, 2009 | Brother GX-6750 Typewriter
BROTHER ELECTRONIC AX-22 RANDOM LETTERS
Check to see if there is a switch on the left side of keyboard for international or symbol printwheel selection.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 17, 2009 | Office Equipment & Supplies
HELP..BROTHER DAISY WHEEL TYPING RANDOM LETTERS AND SYMBOLS
Press the Code button and the Q/Reset button at the same time and the wheel will spin and go back to the correct place.
Feb 06, 2009 | Brother SX-4000 Typewriter
Incorrect characters printing after the third line
Geno111 doesn't know what he's talking about. Look closely at your correction tape once it has passed the daisy wheel. Does it looked roughed up a little? I just had this same error and discovered that my daisy wheel was hitting my tape when spinning and not allowing it to jump characters like it needed to. I simply put a little double sided tape on the daisy wheel cover between it and the metal tab that holds the ribbon at a certain distance, to increase the space the daisy wheel has to spin. It seems to have worked so far. If anyone has a permanent solution, or answer as to how it spins wobbly, I'd love to hear it.
Nov 18, 2008 | Brother ML-300 Typewriter
Random letters/correction tape
You must have damaged the Daisy Wheel when you were fitting c'tape..Fit another wheel..
Apr 10, 2007 | Brother SX-4000 Typewriter
Smith Corona Wordsmith 100 Typewriter Logo
114 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Ekse
Jim Keysor
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
