How do I replace the pump
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
SOURCE: Kenmore Model 110.47561602 - HE2T. The drain
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
