Brother CS-6000 Logo
j
jill pentz Posted on Mar 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you change the light bulb
I can not get machine open
tootsie mason
Level 2:
Sergeant:
  • Expert 180 Answers
  • Posted on Mar 20, 2014
tootsie mason
Expert
Level 2:
Sergeant:
Answers
180
Questions
6
Helped
22281
Points
548
Theres usually at least one screw in side cover of most machines which has to be removed to access the bulb. My serger & sewing machine both do & ive owned several. Newer ones may be different but there has to be an access .hope this helps
Light bulb blinks
You should probably replace the bulb. If the filament is broken, the heat will cause it to open and close as it heats, expands, then breaks contact and cools again. This could also be a problem in an internal connection that is intermittent. Heat causes expansion of parts and that expansion breaks the connection and the flow of electrical current. When it cools off, it makes contact again and the process repeats itself. As the point of break in the current wears from repeated heating and cooling, the contact widens and the time takes longer.
This problem will likely be at a connector, the switch, the bulb socket, or in the bulb itself.
How do you open the sewing head to change bulb on Pfaff 955 hobbymatic
To access the light bulb, use the button-hole foot to lift up the insert on the arm cover. Remove the cover. Hold the edge guide slightly tilted and push it into the opening in the head of the sewing machine. Press down on the lamp housing to hold it still. Push up on the bulb and turn it counter-clockwise. Once the bulb is loose, pull it down and out of the lamp housing. To replace the bulb, continue to hold the lamp housing. Push the new bulb into the housing and rotate it clockwise. Release the lamp housing and then use the button-hole foot to replace the cover.
Pfaff has the manuals for most of their machines here: http://www.pfaff.com/en-US/Support-and-Updates/Support . The Hobbymatic 955 support page is http://www.pfaff.com/en-US/Support/3529 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Pfaff_935_955_HobbyMATIC-manual-EN-FR-DE-NL.PDF . See page 51 (page 59 of the PDF) for the directions to change the light bulb, These pictures may help you see how to get to the bulb. If you need a replacement button-hole foot, see http://www.sewingpartsonline.com/buttonhole-foot-low-shank-new-1932l.aspx .
I hope this helps.
2answers
Board bernina 1030
As you will have noticed, you cannot open the end of a Bernina 1030.
There are two light bulbs on this machine, visible on either side of the needle bar and presser foot shaft. Viewed from the rear of the machine, you can see the one on the right but the one on the left is beneath a transparent plastic cover that slides out easily (but does not come right out).
To remove either of the bulbs, which are a bayonet fit, open the accessories box attached to the rear of the machine and take out the screwdriver tool from the top row, on the left hand side by the bobbin storage. One end of the screwdriver is a screwdriver (!) and the other end has a plastic tube - this is designed to grip the bulb.
Place the plastic tube on the end of the bulb, push a little and rotate anti-clockwise about a quarter of a turn to release the bulb.
The bulbs are both 6 Volts, 4 Watts. board-bernina-1030-yfctketow5dlawzorpkxttl4-1-10.jpg
How do I open the machine to change the light bulb. model ls-1217
Hi
Do you have a manual?
You can download a free manual from the Brother site.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1217_EN_186.PDF
Click on the maintenance section of the manual. The first part of this section shows how to change the light bulb.
Hope this helps!
Light bulb not working
You need to change the bulb.
Most light bulbs in almost all sewing machines are located inside the face plate on the left hand side of the machine.
The faceplate is usually hinged at the back and it opens a bit like a door. It should open fairly easily and close with a click.
Open the faceplate and unscrew the bulb, it should be in plain view.
Look to see if it a screw or bayonet type.
Replace it the same way you would an ordinary bulb.
You can get sewing machine bulbs on ebay but you'll need to know which type of fitting it has before you buy.
Hope this helps!
1helpful
Need to change light bulb
some machines it's called the lamp cover door --these machine have a hinge at the back, carefully pull the door toward the back of the machine & it should open to show the bulb
some machines call it the face plate--there is a hidden screw under a plastic plug, gently pry the plug with a screw driver & then take the screw out, & remove the plate & the bulb should be easy to replace,just put the plate back on after changing the bulb & replace the screw & plug
happy sewing
3helpful
How to replace light bulb at Pfaff Creative 2124?
On these machines you cannot open the left side to remove the bulb. Your machine accessory kit should have come with a rubber tool that is ribbed with a cup-shaped opening on either end. This is a tool for removing the bulb. Tilt the machine with the base facing up so you can see where the bulb is and use this tool to twist the bulb gently. It sould come out with no problem! Hope this helps!
14helpful
2answers
Cannot get to the lightbulb on an Elna SU sewing machine to chang
On the left hand side of the machine on the end cap.
Changing the Light Bulb
The sewing light is located behind the face plate.
UNPLUG THE MACHINE. Wait until the bulb is COOL before you touch it!
1 2 3 Remove screw cap , screw and face plate .
To remove: pull out bulb from socket.
To replace: insert bulb into socket.
Attach face plate and insert screw and screw cap.
NOTE: Replace bulb with same type rated 12V, 5W.
I hope this helps. Don't forget to rate my answer.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
