Dell OptiPlex 330 Desktop Desktop Computer  Logo
A
Anonymous Posted on Mar 19, 2014
Cannot display this video mode
Video mode
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
tip
How to publish and display flv videos online freely
Mac Higosoft Web Player is a web video creator and publishing tool for Mac users. With Higosoft Web Player, you are able to publish and display videos online, and then embed the generated flv player on any websites and personal blog.For detailed information about HigoSoft Web Player, please feel free to visit http://www.web-player.us
Higosoft Web Player is the newly published web video creator and publish tool for you to display flv video online in your own way, such as add ads like text, image,video or swf to redirect people to your websites, you can and embed the generated flv player on any websites and personal blog to promote your product or services. Below is the way to use HigoSoft webplayer
Step 1: Add flv video
Click “Add” button to import videos to this software
You are also able to do some basic setting for the videos, such as specifying hyperlink for the videos when clicking on the videos or when the video playback comes to the end.
Step 2: Add advertisement
In the "Advertise" tab, Higosoft Web Player provides you with two modes to insert ads on videos, including “Insert” mode and “Overlay” mode.
It allows you to add different types of ads inside or over your videos, such as text ads, image ads, swf ads, and video ads
In "Insert" mode, video will be paused to display the inserted object for a while depending on the duration set for the object, and after the duration, video will continue to play from where it's paused
In "Overlay" mode, the added objects will flow on the video and be displayed with the videos in the same time.
Step 3: Choose skin and style
Higosoft Web Player for Mac is equipped with abundant amazing web flv player skins and templates all of which are within "Template" tab.
You can select whatever web flv player your like from various options provided under the "Style" sub-tab, get further control of the apperance of web flv player choosing from "Options" sub-tab, add watermark and logos for your published videos under "Addons" sub-tab and choose choose your favorite preloader when the video is buffering.under "Misc" sub-tab.
Step 4: Publish your videos to website
It is maybe the final purpose for HigoSoft web player, with it you are able to publish and display amazing videos online in a well-designed and elegant flash video player.
When you come to publish the videos online, you have two kinds of publish mode to choose. One is “Embed” mode and the other is “Out File” mode. The difference between these two modes is that under “Out File” mode, the software will generate additional xml file named “medialist.xml”. That is to say, when you publish in "Embed" mode, generally two files produced "dwplayer html" and "dwplayer swf" but with "Out File", the additonal "medialist.xml" file generated.
For more imformation about how to use HigoSoft web player, please visit http://www.web-player.us
on Jun 12, 2010 • Computers & Internet
2answers
Power but no display
It could be a hardware or software problem. You need to isolate the problem.
To isolate the problem, restart your computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight safe mode. Hit enter.
If you can boot to safe mode, then do a system restore inside safe mode to revert the computer config back to a known good date.
If you can't boot to safe mode, then it's for sure a hardware issue and you need to get it serviced by a technician.
David
Yamaha htr-5460 Receiver: all settings show up on the TV screen. Can't get them to go away
Page 21 of your manual!!!!
Happy New Year!
Short display Selecting the OSD Mode 1 Turn on the video monitor connected to this unit. 2 Make sure the AMP mode is selected and press ON SCREEN on the remote control repeatedly to change the display mode. The OSD mode changes in the following order: full display, short display, and display off
6 hours old computer was working fine the shut down to load windows update then there was no video even unplugging and pressing the power button as aspire website suggested i have power but no video and...
Restart the computer and press "Del"key or F2 key.. check whether any responce on display, if BIOS is displayed , then display is ok.
Then restart the computer and press F8 key continuosly till "SAFE MODE" list displaying. if displayed safe mode list, select "Enable VGA mode". then press enter. try to login to windows. then change the resolution if required.
I am trying to connect my Onkyo DS-A3 ipod dock to my Onkyo TX-SR508 receiver and I cannot get the TV to display the ipod menu. I've connected the red and white (R/L) and yellow video cable to the...
Is OSD set to ON? See below
Set the OSD (onscreen display) mode before you start using the RI Dock. 1. Plug in the AC adapter. 2. Turn on your TV and amp, and select the appropriate inputs on your TV and amp. 3. Insert your iPod into the RI Dock. 4. Select the video output mode depending on the video connection. While pressing the remote controller's [SETUP] button, press the Up [ ] button for the component video connection, press the [ ] button for the composite (default) connection. 5. Use the remote controller's [MODE] button to set the OSD mode. On: Playlists (artists, albums, songs, and so on) are displayed on your TV, and you can navigate and select your music or video while looking at your TV. While this mode is selected, your iPod displays the Onkyo logo. Off: Nothing is displayed on your TV and you navigate and select your contents by using your iPod's display.
3helpful
Cannon display this video mode
This message occurs when the display mode in the video settings is outside the parameters of the monitor.
One way to try and get past this is to boot to the F8 Menu (press F8 at startup till you get a windows start menu, and select the "Enable VGA Mode" for WIndows XP or "Low Resolution Mode" Vista/WIndows 7 and let the system boot to a 640 x 480 low resolution. Once at desktop, you can right click teh desktop and go to dispaly properties and increase the color and resolutiont to the OPTIMAL for you monitor.
5helpful
4answers
Error: Cannot Display This Video Mode
You may have to boot into safe mode and reset the video settings to a safe setting like 1024x768.
  1. To get into safe mode, continuously press F8 while the computer is booting up.
  2. Eventually you will get a Windows XP Boot Menu.
  3. Choose the option for Safe Mode.
  4. Go to Start, Control Panel and double-click Display.
  5. On the Settings tab, drag the slider bar to 1024x768.
  6. Click OK
  7. Shut down and reboot.
If the problem goes away, then you are good. Otherwise, you'll have to boot menu again (F8) and choose Enable VGA Mode.
1helpful
No sound,no video,front panel display will display.harman kardon
Check your audio settings on the main menu of the receiver. The audio input should be set to "auto" Next, make sure you don't have the unit in "6 channel input" mode or "direct" mode. This is usually a small button on the front panel. If you check all this and you still have a problem, post a comment and I will help you troubleshoot some more. Hope this helps
Primary display issue
Try going to Windows Safe Mode. You do this by pressing the F8 key repeatedly exactly after you hear your computer beep when it is rebooting. This should bring you to a screen that will have 3 Safe Modes listed, choose just plain Safe Mode by using your arrow keys to highlight Safe Mode and press enter. Once in Safe Mode, a box will come up asking you if you intended to enter Safe Mode, click Yes. You should now see your desktop, however it will look larger, and with less colors. This is normal.
If this mode did not allow you to get into windows, then reboot, press F8 like before and select Enable VGA Mode instead.
Now that you hopefully have a desktop, try this link which will take you to a video that will walk you through the process of setting up your DualView monitors. Also, note that there are some check boxes that allow you to select which monitor you want to be the primary.
I realize this video is specific Windows 2000, but the process is the same for Windows XP.
Hope this helps and Good luck!
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
