o reset the 2013 Hyundai service interval, please follow these instructions to reset/setup:
1.Start the engine.
2. If a service is due the display will show "Service required".
To reset this message, press the SELECT/RESET button (left
pointing arrow) on the bottom right of the steering wheel for more
than 1 second.
3. The service interval will be reset to the default setting.
*The service interval feature has to be turned on and set by
the user by accessing the SERVICE INTERVAL menu. Press
the MODE button (rectangle icons) on the bottom right of the
steering wheel to highlight the SERVICE INTERVAL menu.
Press the SELECT/RESET button to access the menu and
use the DOWN arrow to turn the SERVICE mode on and
set the applicable interval.
4. Turn the ignition off and then start the engine to verify the
indicator has been reset.
- See more at:
http://oilreset.com/2013-hyundai-santa-fe-service-interval-reset/#sthash.MniBNaqR.dpuf
