Memorex MVD2016 DVD Player Logo
A
Anonymous Posted on Mar 20, 2014
Double images side by side
Double images
How to scan double sided i2600
It should be set for duplex and then it will scan both sides unless it is set to delete blank images on the rear
Double Sided Copies on Savin 2535
The image shows a flat page with a 1, arrows to an image of a sheet with the lower right corner turned up with a 2 on it. On a Ricoh, just remember that the first image is the input and the second is the output.
My tv is coming double images
Your question needs some additional and important information:
What is the model number?
What is brand of set, LG is what is posted here.
Does it look 3d?
If double images are they side by side or one above the other or what?
Toshiba LCD TV: Double image (right side) on power on
HEllo,
Did you find a solution to your problem?
Thanks
1helpful
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Hitachi 57'' rear projection tv has double images on both sides.
tv looks in the center and have double and multiples colors . majic focous do not fix t
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2helpful
Image appears double and slighly off when viewing
I was having a double vision problem with my Barska 10-30X50 zoom, 195FT/100YDS binoculars. One image was always higher than the other. This was tolerable at low zoom, but was further aggravated the more I zoomed in. I found that I could grasp both barrels and twist them in opposite directions (one side up, the other side down) and force the two images to merge--but that was a strain and an unpleasant viewing experience. As an experiment, while looking through the binoculars, I grasped the far end of the right barrel and twisted it on its axis. Nothing happened at first, but after a certain amount of resistance it began to rotate independently of the body. Lo and behold, this shifted the barrel's axis, and the image for that eye moved vertically! I turned it until the two images merged, and now I'm thrilled to say that the problem is solved! I don't have a clue if this would work on any other brand or model, but it's worth a try!
2answers
I am getting double images while watching TV;
There maybe some loose components on the circuit and that needs resoldering. Bring it to the repair shop to done.
Dvd player is producing double images
Go into the units system menu and change the unit to NTSC or PAL, depending on what country you live in. Good Luck
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
