Danby Portable Air Conditioner Logo
Posted on Jun 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Danby dpac120068 Air Condtioner, where does the hose go? and do you fill the tank in the back with water?
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Jul 28, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
12564
Points
31
The hose goes into the empty tank or tray inside (if it's the drain hose like a garden hose). When the hot side of the system goes past there it evaporates the condensation dripping into it. If your talking about the big 4 inch hose, that goes out a window to get rid of the heat from the room.
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Jun 18, 2009
Anonymous
Expert
Level 2:
Answers
52
Questions
Helped
27303
Points
142
Hose goes into a bucket or out a window, drained, etc. it's the drain hose for the condensation. alternatively you can use the tank to catch the condensation, which must be emptied periodically.
2answers
Where can in get a set of exhaust/intake hoses for a danby dpac120068 air conditioner
Is there a reason not to just go to the Danby site? Support Danby includes phone support, email and "Find Parts" Even if their source is out you should at least be able to find the correct part number, then Google Danby (part number).
You could also look to see if generic flexible vinyl tubing/hose can be substituted. It's doubtful that Danby created their own hoses.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Red light and beeping on danby air conditioner dpac120068- what does that mean
Hi There,
If you have check and emptied the water bucket, the problem could be the water level sensor. Please contact our customer service department to be connected to a technician who can assess the unit. The office hours are Monday to Thursday 8:30-5pm and Friday 8:30-4pm. The phone number to call is 1-800-263-2629
Thanks and have a great day!
Water alarm is on. How do i drain. I think I need to hook up a hose in the back of the unit to drain but I don't know the procedure. There are three drains that look ike they would accept a hose, one high...
The hose is optional. If you are lucky enough to have a drain nearby, then route the hose downhill from any of the three holes on the back. But it won't pump the water uphill out a window. In that case, you will have to install the ginormous external tank and empty it every day. fun fun
The red light comes on as if the tank is full of water but its not draining to the exterior tank which is properly attached... I have even manually drained the interior tank from the back at the bottom......
Does the LCD display show a "tank" icon? If not, the pump will not be allowed to empty the water into the tank. This is because the sensor is not detecting the external tank. If the tank is not properly secured to the unit, the magnet is too far away from the sensor. If the tank is secured, try putting a strong neodymium magnet there to temporarily trick it.
2answers
My air conditioner is leaking from the front of it
Are the three drain plugs tightened?
If you're stumped, try to drain the inside tanks and see what happens: Unscrew the three drain valves at the back, and put a pan to catch any water (only a few cups). Let us know what happens.
I have a 7 year old danby portable air conditioner it seems to work good but my neighbor just purchased a new 12000 mine is 10000 he said he has to empy water frequently We have never had a drop of water...
This model is designed to heat the condensed water and send it out the exhaust duct as vapour. It prevents accumulation on less humid days. It sounds like it's served you well for seven years.
However, I do recommend one step for owners of the DPAC series. At the end of the season, drain the internal tank by opening the two taps at the bottom rear. Put a pan beneath them . The internal tank only holds one cup of water.
2helpful
When I turn on the ac, it beeps many times the red light says on
why did it fill up? because the drain is plugged there should be a safety switch that is keeping the comp off. find and clean the drain system.
2answers
Trouble setting up the Danby DPAC120068
Hi, you have to put the support for the tank under and it will lock
Top Danby Heating & Cooling Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
