It sounds like there may be an issue with the power supply to your Yamaha Electone HS5. Here are a few things you can try to troubleshoot the problem:
Check that the power cord is securely plugged into the back of the Electone and into a working outlet.
Make sure that the outlet you are using is functioning properly by plugging in another device to see if it powers on.
If the power cord and outlet seem to be working properly, try resetting the Electone by unplugging it from the wall and waiting a few minutes before plugging it back in.
If none of these steps help, there may be an issue with the power supply unit inside the Electone. In this case, it is recommended to have the instrument serviced by a qualified technician.
soy usuario de un teclado yamaha y queria saber si me pueden enviar las partituras de iniciacion al teclado. gracias mi nombre es Pedro Guardia Berrueco. Mi direccion de E.MAIL: [email protected]. el modelo es psr-E223-YPT-220
Noise issue: Make sure the following is adhered to:
ALL interconnected equipment is powered from the SAME receptacle or power conditioner.
ALL interconnecting audio lines are BALANCED, either XLR or TRS cables.
Read these "ALL"'s as just that. Some people unaware of the noise and HAZARD to their equipment will power mixers from one receptacle at one end of the room and speakers/amplifiers from one at the other end. The Professionals know better and run a heavy extension back from stage alongside their snake. Ground bounce noise is not only annoying, but can destroy audio input circuits.
