Computers & Internet Logo
t
tim kopf Posted on Mar 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I've forgotten my imap password
What can I add?
Amit Verma
Level 2:
  • Expert 102 Answers
  • Posted on Mar 23, 2014
Amit  Verma
Expert
Level 2:
Answers
102
Questions
Helped
27419
Points
209
There is no such thing like IMAP password. It will be your email address password that works when you configure email into outlook.
tip
How to setup your email into your iPhone
First, you need to know your IMAP incoming and outgoing mail servers. These servers can be provided by your email service provider. Once you have these info, you may follow the steps below:
1.Go to 'Settings' on the main menu on your iPhone.
2. Click on Mail, Contacts, Calendar...
3. Select Add Account and tap 'Other'
4. Add mail account and then fill out the lines with your name, e-mail address and password then tap 'Save'.
5. Select IMAP and then use the information below:
* Incoming Mail Server *
- Host Name: type the IMAP incoming server
- User Name: type your complete email address
- Password: your e-mail password
* Outgoing Mail Server *
- Host Name: type the IMAP outgoing server
6. Tap Save button.
Thank you!
on May 03, 2010 • Cell Phones
1helpful
How get into email by phone
Hi James
o Set Up Email on Your Android-based Device
  1. Open your device's email application.
  2. If you already have an email account set up, press Menu and tap Accounts. Press Menu again and tap Add account.
  3. Type your Email address and Password, and click Next.
  4. If you have IMAP, tap IMAP. If you're not sure, tap POP3.
  5. Use these settings for your incoming server, depending on the type of email you have: POP3 Username Enter your full email address. Password Enter your email account password. POP3 server pop.secureserver.net Port IMAP Username Enter your full email address. Password Enter your email account password. IMAP server imap.secureserver.net Port
  6. Use these settings for your outgoing server:As a troubleshooting step, you must have enabled SMTP relays for your account. For more information, see See your SMTP relays.
    SMTP (Outgoing Mail Server) SMTP server smtpout.secureserver.net Port Security type None
  7. Select Require sign-in and make sure your Username (your full email address) and Password are correct. Tap Next.
  8. Tap Next again. Name your account and enter the name you want to display on outgoing messages.
  9. Tap Done.
That's it. If everything is working OK, you should see some email messages. To make sure you can send messages, go ahead and compose an email and send it to yourself.
Mar 04, 2016 • Cell Phones
Lost password
click on forgot password then you enter the email you used to make the account and then you will be sent a password reset link.
Imap keeps asking for my password which i have forgotten how can i make contact with imap and submit a new password
Go to TOOLS -> OPTIONS -> Advanced -> Passwords and Security ->Manage Stored Passwords
Click the appropriate entry (beginning with imap://) and click remove. TB will prompt you to enter the password when you restart the program.
IPhone 3G..been receiving email from aol account on iPhone for quite some time with no problem...now receiving message imap.aol.com not responding...I've deleted account and added it back...I've...
Sometimes the services change their setup. The current setup for AOL to support IMAP is:
Incoming mail server (IMAP): imap.aol.com
Outgoing mail server (SMTP): smtp.aol.com
Make sure port settings are:
IMAP-993-SSL
SMTP-465-SSL
I cannot configure my gmail account with outlook in ultrasurf
Please follow steps below to setup your Gmail to work with Outlook:
Before you can configure Outlook to work with Gmail, you must configure Gmail to work with Outlook. To do that, you must enable the IMAP protocol for your Gmail account. Here are the steps:
1. Log into your Gmail account.
2. Click the gear icon at the top right, then choose Settings.
3. Click Forwarding and POP/IMAP to bring up the POP and IMAP settings.
4. Click Enable IMAP.
5. Click Save Changes.
After you configure Gmail for IMAP, you can add your Gmail account to Outlook. Here are the steps for Microsoft Outlook:
1. Start Outlook.
2. Choose File > Account Settings.
3. In the Account Settings dialog box, click New.
4. Choose Email Account, then click Next.
5. Choose Manual Setup or Additional Server Types, then click Next.
6. Choose Pop or IMAP, then click Next.
7. In the Add Account page, enter the following information:
Your name: The display name you'd like to use
Email address: Your complete Gmail address (ex: [email protected])
Account type: IMAP
Incoming mail server: imap.Gmail.com
Outgoing mail server (SMTP): smtp.Gmail.com
User name: Your complete Gmail address (ex: [email protected])
Password: Your Gmail Password
8. Click More Settings. 9. Click the Outgoing Server tab.
10. Select My Outgoing Server (SMTP) requires authentication.
11. Select Use Same Settings As My Incoming Mail Server
12. Click the Advanced tab.
13. Enter the following information:
Incoming server (IMAP): 993
Use the following type of encrypted connection: SSL
Outgoing server (SMTP): 465
14. Click OK to close the More Settings dialog box.
15. Click Next.
16. Be patient while Outlook tests the connection.
17. When the test completes, click Close. (If the test is not successful, carefully double-check all of your entries.)
18. Click Finish.
I"ve forgotten my device password.
If you forget your password, call you cellular phone company for assistance.
Jan 10, 2011 • Cell Phones
4helpful
How can i get me sky emails connected to my i phone
Log into Sky webmail, click mail settings, forwarding and pop/imap
enable IMAP.
iPhone:
Configure your mail client:
1. Tap Settings.
2. Tap Mail.
3. Tap Add Account.
4. Tap Other. (Note: Don't tap Sky Email; if you do, you'll set up POP rather than IMAP. We are aware of this issue and are currently working to make setting up Sky Email more intuitive for the iPhone).
5. Make sure that:
- The IMAP tab is highlighted
- Host Name is imap.tools.sky.com
- Username is your full Sky Email address, including '@sky.com'
- For Outgoing Mail Server (SMTP), Host Name is smtp.tools.sky.com
6. Tap Save.
And you've finished. You can verify your Advanced settings by tapping Settings, then [your Sky Email IMAP Account] followed by Advanced.
Incoming Settings:
- Use SSL: ON
- Authentication: password
- Server Port: 993 for IMAP.
Outgoing Settings:
- Use SSL: ON
- Authentication: Password
- Server Port: 465
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Grand Canyon Tech
Grand Canyon Tech
