Tablets & eReaders Logo
c
caitlin anderson Posted on Mar 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sound problems on tablet
The sound on my tablet isnt working and it started with these headphones i bought but the were fine when i used them before but now when i take the headphones out the tablets sound doesnt work. is there a way i can fix it without breaking the tablet or taking it into the store? its a nextbook andriod tablet 8
downhille
Level 3:
  • Master 400 Answers
  • Posted on Mar 23, 2014
downhille
Master
Level 3:
Answers
400
Questions
Helped
99646
Points
1167
It sounds as though the switch on the phone jack is not making connection when the phones are unplugged. You can probably clean it by spraying some contact cleaner in the jack, then plug and unplug the phones several (lots of) times. I've had good success with WD40, but it does leave a residue. If this does not fix the problem, you can open the tablet by gently prying the screen off with thin blade (a knife might work). Work your way around the entire screen until the body separates. Gently open and perhaps you can access the jack switch to clean it, if it is not sealed. I hope this is helpful to you.
5 Related Answers
A
Anonymous
  • Posted on Mar 14, 2008
SOURCE: Scrolling problem?
Unplug usb, reinstall driver ,plug usb back. Or restart computer. I have the same annoying problem. It's the only solution i found.
It's nice having that kind of problem when clients are next to you, and you have to crawl under your desk to unplug the usb, and re-install everything. Makes it totally solvable.!
Hope they fix that problem with new drivers!!
Anonymous
  • Posted on Aug 06, 2010
SOURCE: Portege M200 Tablet PC: my tablet pen stopped working, what can I do?...
My tablet pen stopped working what can I do?
Anonymous
  • 51 Answers
  • Posted on May 07, 2011
SOURCE: When turning on my
Try doing a hard reset. Just take the battery out or hold down the power button of x amount of seconds
saad abdeen
  • 167 Answers
  • Posted on Jun 26, 2012
SOURCE: nextbook will not com on
check the battery otherwise it is the hardware problem in your tablet pc
Anonymous
  • Posted on Dec 19, 2012
SOURCE: I can't unlock my nextbook tablet
If you're willing to reset to factory defaults, then there is a way to fix this. However, the reset will delete all data and any apps installed that didn't come with the Nextbook Tablet originally.
Just bought the 10.1 IRULU tablet and the sound does not work?
If it's still in warranty, return it for a replacement. My experience with iRulu was that their Quality Control was/is minimal at best.
Y cant i hear anythig on my tablet
First, restart your tablet. A tablet is a computer, and any computer needs a reboot every few days. Second, check the volume settings. You may be able to increase the volume and hear just fine. If your speaker is bad, you could use a bluetooth speaker or headphones to listen to sound. Also, try different content, sometimes videos do not have sound. I hope this helps.
2answers
My headphone jack not work when i put it in my tablet i can still here the sound from my tablet and the headphones from the tablet it is a irulu Tablet,
Make sure you push the headphone plug into the jack completely. If you're sure that it is, then the jack on the tablet has failed. The sound gets switched from speaker to headphone in the jack itself.
2answers
Why is sound not working?
which sound,? SPEAKER RINGER OR EARPHONE?
try with headphone,,,,check if there is headphone sign on display without headphone?
Orbo Jr. tablet. sound comes out of headphones but not without the headphones plugging in. I did a factory reset but no luck. Help
"No sound on external speaker" problem is often caused by:
- damaged speaker,
- damaged headphone jack,
- damaged audio codec (hardware).
You can try to ask your problem here: https://www.elvikom.pl
There are many service technicians with high-level experience, which may help you to repair your tablet.
4answers
When I plug the headphones into my Samsung Galaxy 10.1 tablet, the sound comes from both the headphones and the speakers on the tablet, shouldn't the speakers be turned off by the headphones?
This can be a hardware (bad headphone jack) or a software (rom update) issue. If the tablet is in warranty, try taking it to your dealer and see if they have a fix.
Otherwise, some people have had success doing one of the following:
1. Plug headphones in after starting music. Watch for headphone icon to appear on screen, meaning tablet has recognized that headphones are attached. Make sure plug has been put into socket all the way.
2. Install app SoundAbout on your tablet and see if you can route sound to headphones only.
3. Check Settings/About Device to see if there is a software update for your tablet. Install the update and see if that fixes the problem
Sound won't differentiate between right and left speakers on headphones
Check if 'Mono Audio' is on (you find it under 'Settings', 'General', 'Accessibility').
1helpful
2answers
Fujitsu T series; no sound when I plug in the headphones
I have the same problem and just figured it out. Go to the sound settings and set the earphones as the default. I just did this and it now works.
Top Nextbook Tablets & eReaders Experts
NOEL
NOEL
john h
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
