Sears runs a resource called Parts;sDirect, you can get parts for appliances, tools, lawn equipment,etc. Need the model and serial #, it'll have exploded views of the different subsections. All.parts on the exploded views are numbered & correspond to a catalog page alongside the picture, with the cost posted. I've used it repeatedly, very accurate, prices are competitive.
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
reset the remote: undo the Philips screw on the back and prize ip the circuit board, then turn it over, keeping the battery in place. There is a slide switch on the back; move it all the way to the left, pause, then all the way to the right, pause again (10 seconds) then move it about a third of the way to the left until it drops into a dent. Carefully reassemble, keeping the battery in place. If this doesn't work, you probably need a new circuit board (receiver) in the fire.
1 clean flame sensor 2 clean burner YouTube video 3 clean heat exchanger Start with 1,ect Rheem website has instructions or call they will e-mail info.
sounds like the orfice is clogged or the pilot assembly needs cleaned ..try tapping an the assembly while it is lit ..to see if the flame straightens up. if so clean the assembly with a tooth brush or small wire brush..good luck... let me know if it works/ joe/
