Brand new tablet will not turn on
Make sure it is fully charged. Hold power button down for about 10 seconds and wait if nothing comes up press power again for half a second. Still nothing? Then put it on charge, it should show that it is charging with a light of a picture on the screen. If there is no sign of charging, wait about 3 hours leave the charger connected and press the power button again for about a second and wait for it to turn on or for the picture to show it is charging appears on the screen, (make sure the charger is on and connected) . Press the power button again for another 5 seconds and wait. sometimes it takes a little while to turn on, especially if the battery is very flat. Other things to try are check the charger on another device e.g. another table or a phone if you can and try another charger on the tablet if they are compatible, (usually the same plug is o.k, check the voltage is the same. most chargers are USB 5v). It may need a more powerful charger than most small phones,. you can try plugging the USB cable into a car charger or USB 3.0 port on a computer. 2 amps is common for most tablets. Apple may be different, hard to be exact without knowing brand etc.
If all else fails see the retailer
