Systemax Venture VX12 Desktop PC  Intel Dual Core E5400 27GHz genuine Windows 7 Professiona (SYX3065) Logo
A
Anonymous Posted on Mar 24, 2014
Upgrade Systemax Venture VX12 xp to windows 7
Directions to upgrade from xp to windows 7 professional when files of latter are already in computer.
5 Related Answers
Anonymous
  • 126 Answers
  • Posted on Nov 23, 2008
SOURCE: No Audio
I have a friend with a systemax, same thing happened to him.
Go into the control panel, select sounds and audio devices, go over three tabs to the audio tab, make sure the sound default device is the onboard audio card. Should be all set.
Let me know how it works out.
Anonymous
  • 679 Answers
  • Posted on Dec 15, 2008
SOURCE: pc does not go beyond Lsass.exe application error
Try getting into safe mode, by taping the f7 or f8 key before it boots. Once in safe mode we can do a restore to the last restore point, and go from there. If you can't get into safe mode, let me know and we will go into the bios, set the machine to boot from the dvd drive and use your xp disk to boot her up, this method id too much to post here, let me know and we will take it up only if needed. Also try this, turn off any user accounts that the computer has installed other than your administrator account, and let me know what happens
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on Feb 23, 2009
SOURCE: I have a Systemax Venture computer that is 3 years
Hi there.
Remove all power to the desktop, remove the side panel, power the machine up and check that CPU fan is working, if it is turn the computer back off, get a clean, dry paintbrush and gently clean the fan blades and the metal heat sync behind the fan of dust, then restart the PC to see how long it stays on for. If this time it stays on it was overheating.
Good luck and thanks for using Fixya!!!
Anonymous
  • 212 Answers
  • Posted on Nov 04, 2009
SOURCE: need help finding drivers for Systemax Venture
go to this website http://www.systemaxpc.com/support.php
You will find them there. good luck.
Anonymous
  • 477 Answers
  • Posted on Apr 06, 2012
SOURCE: setting up windows XP on Systemax venture computer says set up can not access this disk
If you installing a new windows you should first delete all partititons and then create one and install windows on that. Remeber all data on your harddisk gonna get deleted. So press d to delete and then c, then enter on the new partition
Can I change from Windows XP to Windows 8 on my current Systemax hard drive
Yes you can upgrade from Windows XP to Windows 8, depending of the age and specs of your computer it might run slow, you will need a minimum of 2Gb of memory to run Windows 8 at a decent pace.
3answers
My windows 7 build 7601 is not genuine? what do I do?
you needed to download window 7 activator from http://cnet.in/ download and run the window loader file and choose your PC brand and then install it... it will run in background... after few seconds the PC will ask you to restart the computer press OK and enjoy your window 7 activated
How do I recover or repair bootini and bootsect for Windows XP Professional after uninstalling Windows 7 Ultimate?
It's good that you have the recovery cds. Do NOT reformat the hard drive. Restore with the cds so you'll have a clean install . You will need to have any software cds that did not come with the original pc in order for them to rebuild the registry entries. That is the easiest way because there won't be any left over files from Windows 7 after you restore to XP.
Problem setting up windows XP
D to Delete all the partitions on the drive to get all the space into one big contiguous space. Then try installing.
How can I copy, the 27 House photos from Facebook, to My Documents File
Copying pictures from faceBook is easy.
Right Click on the picture you want to save choose from options Save image as give a name direct the location my documents on your computer click ok!
3answers
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
3answers
When we try upgrading xp to windows 7 the upgrading failed because our cpu is old can i upgrade my xp to windows 7 using a old cpu or use a new cpu
NO you cannot, on that same computer, no matter what OS, because, you MUST change your central Processing Unit, CPU. To allow Windows 7 to work correctly.
System properties, xp pro
1. Click Start
2. Click Run
3. Type this in the run box: c:\Windows\System32\oeminfo.ini
Something like this should open in notebook:
[Version]
Microsoft Windows Whistler Edition
WinVer=5.01
[General]
Manufacturer=vpr Matrix ™
Model=Personal Computer
SupportURL=http://matrixsupport.net
LocalFile=c:\matrixsupport\file.html
[Support Information]
Line1=”Visit us online or call our toll-free Customer Support number 24/7!”
Line2=”http://www.vprmatrix.com”
Line3=”cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif(800)332-4800cb_transparent_r.gif in the USA and Canada.”
Line4=”"
Although I wouldn’t play with anything under the version section, you can edit the information in the other sections. You can edit anything to the right of the = sign.
Save it before you exit notepad and you’ll be set.
You can also edit the bitmap that will be displayed on this screen by changing this file:
It must be 172 X 172 pixels in size.
No Audio
Top Systemax Computers & Internet Experts
Ngoro
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
