It won't play dvds from the uk. How do I unlock the regions
SOURCE: Need To Unlock My Sony BDP-S500 To Play Imported DVDS And BLU-RAY
I don't think that it is illegal to change the region of a DVD player as a DVD drive in a computer can be changed easily up to 5 times before they are locked on one region. Sony Blu-Ray players at this point don't have a hack code and they have to have a hardware mod to play both region A and B Blu-Ray discs. There are inexpensive Phillips DVD players that are region free or they have an easy method to make them region unlocked. I don't know of any Blu-Ray players that have that feature, but you can get a N. American region coded player that will play both PAL and NTSC, but you will have to use a voltage converter as N America is 120V 60Hz and Europe is 220-240 @ 50hz.
The other option is to get a Blu-Ray/DVD RW drive for your computer and set it as a region 1drive and connect it to the TV for playing US discs.
There are other things you can do but those ARE illegal or questionable and I can't post them here.
Best of luck
SOURCE: Region code for Sony BDP S300
http://www.hometheaterinfo.com/dvd3.htm
http://www.dvdregionhacks.com/
Testimonial: "I still couldn't get the info i needed from the links, so unless i'm missing something the advice wasn't helpful."
SOURCE: I purchased dvds from ebay and they will not play
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
I found these codes for all the other DVP-SR series players, yours was not listed but I thought was worth a try.
SOURCE: I want to make my
1.Make sure no Disc in tray
2.Press " HOME " on Remote
3.Press Number keys " 1389310 "
4.Power off then Back On
Now try a non-Region Disc
