Question about Samsung Tablets & eReaders
Galaxy tab 2 10.1 does'nt show thw level ef charge
For no reason tablet stopped working and the logo of Samsung appear have to leave the batterie empty. After opening case i disconnected the battery reconnect everything and charge it but without showing the level of charge whats happening tk you
  • Norman C
    Norman C Mar 27, 2014
    We're on facebook and suddenly the screen went black and the logo of samsung appeared.Wasn't able to do anything after that, so I left the batterie on till no power left. After that i opened the case and disconect the baterry for a few minutes. After reconnecting everything and close the case I recharged de battery. Now it seems to have power but nothing appers on the screen. The battery level did not appear. thank you
  • 27 Answers
Try Resetting the Device Cache Partition by booting in to Recovery Mode.
o turn ON in Recovery Mode:
Step 1: Power off device completely (You Might need to Keep it on charge)
Step 2: Press and Hold "power" + "Vol up" for 5 sec
Step 3: Notice it flash boot screen twice
Step 4: Enter recovery menu use vol up and down to navigate
Step 5: Press power button for confirmation
Step 6: Wipe cache partition.
if clearing the cache partition doesn't help, you can also try resetting your device by formatting it to factory settings (ALL DATA WILL BE DELETED). for this Repeat the Steps upto 5, then use Step 6: Wipe data and clear cache.
Post Thanks if it helps
Posted on Apr 02, 2014
6ya staff
SOURCE:
shajanrs
Shajan RS
  • 890 Answers
SOURCE: i need to download user manual for samsung galaxy
You can download the available documents from the following website.
http://www.samsung.com/uk/support/search/supportSearchModelResult.do?menu=SP01&searchWord=galaxytabpc&default_searchInputBox_value=Enter+model+number+or+keywords&searchInputBox=galaxy+tab+pc+
Please let me know if you require any further assistance.
Thanks
Posted on Mar 06, 2011
Marcu Catalina
  • 95 Answers
SOURCE: i just bought a samsung
Hi! First of all in user's guide manual says that this tablet works just fine with only 3 IM : 1.Google Talk; 2. Windows Live Messanger 3. Yahoo! Messanger. Try one of those to see if the camera button appears.
However, if you need more information you can find them here: ( http://www.userguidemanual.com/samsung-galaxy-tab-gt-p1000-tablet-manual-user-guide-french-english/ ). *This link allouds you to read and download free user's guide manual (in PDF format).
I hope this will work! Have a nice day!
Posted on Sep 02, 2011
Arun
SOURCE: My samsung Galaxy Tab GT
Somehow this is related to the SD card. I had replaced the original 2 GB SD card with 8 GB one and it was working fine. I used to use the flash as a torch by using the record function with flash and then pause which leaves the flash ON to be used as torchlight. But then it broke down displaying Camera failed. I did lots of troubleshooting but it didnt work, finally I inserted the original SD card back and the cam started working. Try this:Switch Cam Storage to SD card then remove the SD card from the cell and reboot the cell without the card. let the cell work for few mins(30 to 60mins)without the SD card. Now insert the SD card and reboot the cell. wait for few mins and check. Replacing the SD card from another cell may also work.Good luck
Posted on Nov 22, 2011
KingDWS
Dave King
  • 1606 Answers
SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Posted on Mar 23, 2012
peter4sons
Peter Uys
  • 5 Answers
SOURCE: why is there a red cross on the battery icon of galaxy tab though its fully charged?
I studied my galaxy note 10.1. when i use the original wall charger it charges well, fast an no red cross appears. when i hook it to the usb of my laptop then the red cross apears and the tab reports that it is not on battery ( look at the time on battery it does not change) the battery also remains at the same charge level that it was when i hooked it up. when i use the car charger it does the same as with the laptop. my conclusion is that when hooked to the car and/or laptop the battery does not charge, but the tablet is running of the power from the external source and not the battery. this seems to be a very clever move from samsung to preserve the battery when it cannot be charged by the device it is hooked up to.
Posted on Oct 23, 2012
Why wont my Samsung Galaxy tab 3 notcharge past 60%
The battery may be unable to charge to more than the 60% level.
Oct 07, 2016 | Samsung Galaxy Tab on 3 Mobile Tablet PC
My tablet has safe mode in left corner,hOW DO YOU SHUT IT OFF?
Get an Android Tablet out of safe mode - Support Home Page
acer--uk.custhelp.com/app/.../get-an-android-tablet-out-of-safe-mode
How do I get my Android tablet out of safe mode? Use the ... Restart your device by holding the power button, then tap Power off. ... Did this answer help you?
Samsung Galaxy Tab 3: Turn Safe Mode On or Off
www.technipages.com/samsung-galaxy-tab-3-turn-safe-mode-on-or-off
Mar 15, 2014 - Use the Safe Mode feature on the Samsung Galaxy Tab 3 to start the Android OS with the system default software. ... When the Galaxy Tab 3 logo appears on the screen, press and hold the "Volume Up" button. ... Once the device has completely powered off, you can press the "Power ...
Galaxy Tab 4: Enable or Disable Safe Mode - Technipages
www.technipages.com/galaxy-tab-4-safe-mode
Mar 4, 2015 - A tutorial about how to turn Safe Mode off or on for the Samsung GalaxyTab 4 tablet.
Power the Device Up in Safe Mode - Samsung Galaxy Tab 2 ...
Jan 20, 2016 | Tablets & eReaders
Why wont my Samsung Galaxy Tab on 3 Mobile Tablet PC charge
either your battery is shot as in dead or your charger is faulty
you could try to charge it using a usb lead in your computer or another usb port to see if that works , or try another charger to eliminate your lead /charger you are using
Aug 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Samsung galaxy tab 2 7.0 won't turn on it will go as far samsung on the screen that's it
try to hard reset it:
1. turn it off
2. press volume up + power button
3. when logo appeared leave the power button but not the volume button
4. choose from recovery menu wipe data/factory reset then select yes then choose wipe cache partition using volume buttons to navigate and power button to select.
Feb 06, 2014 | Samsung Galaxy Tab Tablet PC
My Samsung Galaxy Tab P6200 is gone unexpectedly and cannot be switch on and i try charging it and it shows only danger sign.what should i do please? Read more: My Samsung Galaxy Tab P6200 is gone...
My first guess would be you have a broken battery. Try to open it and measure the battery. If it's above 3.7V, it is fine. Then you have to consider that your motherboard is broken. You should always try to replace a broken part yourself first. search model name plus "repair guide" on any search engine.They will show details about about part replacement etc. in detail. There are other websites that sell all the replacement parts, one of the bigger ones is http://portatronics.com (646) 797 2838.
Jan 04, 2014 | Samsung Galaxy Tab Gt-p6200 7.0 Android...
Samsung battery wont charge need to reset it
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 15, 2013 | Samsung Galaxy Tab Tablet PC
Samsung tablet 7.0 will not turn on
Note: These steps clear data from the device. SD card data like your photos and music are not erased unless you choose to format the SD card.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Upuntil the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. PressHome to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
If you have access to the OS, you can also perform a hard reset in Settings.
1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
Sep 13, 2012 | Samsung Galaxy Tab Tablet PC
Why is there a red cross on the battery icon of galaxy tab though its fully charged?
Nov 12, 2011 | Samsung Galaxy Tab (GTP1010CWAXAR)
Hi guys, during upgrade I did something wrong. So, now I have on screen of my tab logos of pc and mobile with triangle in between. No charging, non responding, no hard reset available. Please, help...
Have you tried the hard reset? Try these instructions for a hard reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
Mar 02, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
66 people viewed this question
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
