Sony ericsson xperia x8 E15i pattern unlock,i forgot pattern lock
SOURCE: need a unlokcing code for my new sony
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
SOURCE: how can i pass a song via bluetooth to another
1.select a song
2.go to option
3.there you can see the send option
4.select the sending option(bluetooth)
5.the bluetooth will search for available bluetooth connection
6.select the bluetooth connectivity which you have to send
SOURCE: i can't find the caller
call groups are under contacts you will see a setting for it or when editing or saving somone ,camera zooms in and out wit the volume button.. if helpful plz rate.
SOURCE: how to turn on chinese writing for sony ericsson
You need to make sure you have chinese input method installed. You may check this in the settings-> Applications -> Manage applications or setings->Language & keyboard. If not, you can find and install one from the Android Marketplace. One of the good one could be the Google pinyin. Also, the fashion Swype input method also supports chinese input as a beta function, but you have to root your phone to install this. After this, you can check the setings->Language & keyboard to enable and setup the input method of your choice.
