Joy, to help answer your question better, you may want to post a photo here or provide a Model and Serial number off of the unit. Once you've done this we can move forward with offering advice!
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
this is only a week old, you should call the repair facility or consult your owners manual to be sure that the unit is or isn't doing what it is supposed to do. This should still be under warranty, so the place you purchased the unit from should be able to help you the best.
Joe
