New filter, but I replaced it just in case and 2nd new filter behaves the same way. When I try to fill a glass, I hear the selonoid click and hear the standard buzz but no water comes out. If I try to remove the filter, I get a little spray of water as I remove it, indicating to me it's pressurizing the filter, but not allowing water out. Any Ida's?
Good Morning Joseph,
I see that you are having trouble with water dispensing and ice being produced on your Frigidaire refrigerator, even after replacing water filter, model# ULTRAWF, twice. I would suggest to reset your refrigerator, by either unplugging it, or shutting the power off at the circuit breaker for at least 2-3 minutes. Once power is restored try to get water out of the dispenser. If you are still having trouble with the water dispenser, remove the water filter and replace it, making sure you hear two clicks and the filter is flush with the filter housing. If these suggestions do not work, I suggest contacting your local authorized technician for further assistance.
-Best Regards-
WP
SOURCE: wiring ice maker old ice maker has a 4 square plug
wiring is different and you will probably short out something. this is 120 volts and you could get a shock! leave this to a professional. other wise the only thing i would tell you is compare the electrical schematics from both ice makers to varify power and control wiring.
SOURCE: ice maker is not getting water to make ice
Frequently,the small valve that is tapped into the water supply that feeds the ice maker(usually a water pipe near the unit) becomes clogged.Turn the valve all the way in then out a couple of times.This generally frees the calcium buildup. The water should flow.
SOURCE: Bad tasting ice after i replaced the water filter?
Use an external water filter first so the water supply is already filtered. Have you sanitised inside?
SOURCE: Ice maker water freezes before getting to Ice maker
likely you have a bad water valve where the water goes into the fridge. The valve is not sealing all the way and the water is dripping even when it closes allowing the water to freeze up
SOURCE: Why does the ice maker in my Frigidaire model# FRS6HR4HW1 refrigerator not receive any water?
Could be the solinoid valve that lets the water throuh to the ice maker. i I would check the coil on the valve for a curciut
