Sounds like the thermostat is not working. Mechanical and electronic thermostats can go bad and cause the freezer to continue running no matter what setting is set on thermostat. When this happens the only setting that will work is turning the temperature setting to off. What is the model number on your freezer? Sea Breeze
There are different models made for holding different products. Yours has a 1/3 hp compressor for above 20 degs. It may have 0 on the thermostat and may well pull down that far, but -20 would be out of it's reach. Where as it's sister model is made to freeze to below zero has a 3/4 hp compressor. Larger compressor for the lower temps.
This is about time I believe your defrost drain has become blocked and is not allowing your defrost condensate to exit your freezer. Click here=> AFU2067AW Drain System Service Information.jpg This will explain just where to begin and Click here=> Leaking Refrigerators Just What may Be HappeningOnce there click on all of the links and read just what it will take to solve this problem. If you have any questions please ask. Please rate these solutions, Thanks, Sea Breeze
I think you have tell wrong model .
Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid
Sliding Doors
Durable white powder coated, baked on enamel finish
Solid sliding top doors
Cord and plug included
Self-contained refrigeration system
Temp. range 0 to -18 degrees F
13.7 cu ft capacity
Heavy duty casters included
Dual drain plugs for easy cleaning
Environmentally friendly CFC-free R-134a refrigerant and insulation
115V, 4.5 Amps
51 1/2"W X 25 3/4"D x 34 3/4"H
One year parts, 90 days labor warranty plus 3 year compressor warranty
&2. Caravell GST-5213.7 cu ft Chest Freezer With Glass
Sliding Doors
13.7 cu ft capacity
115V, 4.5 Amps
What is it? A single door or a double door unit. If a single door, what temperature does it go down to? lower than 0 deg. c or +/- 3 to 5 deg. c In other words, lower than o it is a freezer. Above 1, it is a fridge..
