How to make a Counter Strike 1.6 Dedicated server
What do we need ?
HLDSupdatetool -> http://www.steampowered.com/download/hldsupdatetool.exe
NoSteamPatcher -> http://www.gameszone.ro/downloads/no-won-steam.zip
AdminMod + MetaMod -> http://ovh.dl.sourceforge.net/source....50.60-win.zip
StatsMe -> http://ovh.dl.sourceforge.net/source....3-cstrike.zip
Step 1
Create a dir were the server will be installed example C:\HLDS
Open hldsupdatetool.exe, click next , then I agree we will get to the destination folder, here
we press browse and select Local Disk C , then double click the HLDS folder. OK finish the
steps
Step 2
click Start , then Run , type "cmd" , in the command line type cd C:\hlds
Step 3
if you se in the command line C:\hlds , type hldsupdatetool.exe -command update -game valve
-dir .
what this does ? it just start downloading in to the server directory all the latest files
needed by the server to run it will download the latest server aplication.
After you se "HLDS installation up to date" in the command prompt we will install the Counter
Strike mod for the server
Like before at C:\hlds type hldsupdatetool.exe -command update -game cstrike -dir .
after the mod is downloaded the message "HLDS installation up to date
Patching the server to accept Non Steam Clients:
Open no-won-steam.zip wich you have downloaded extract everything in C:\HLDS
Server CFG
In C:\HLDS\cstrike there is a server.cfg file open it with wordpad delete everything in it and
paste the following cvars:
code:
hostname "<HOSTNAME>"
mp_autokick 0
mp_autocrosshair 0
mp_autoteambalance 0
mp_buytime 2
mp_consistency 1
mp_c4timer 35
mp_fadetoblack 0
mp_falldamage 0
mp_flashlight 1
mp_forcecamera 3
mp_forcechasecam 2
mp_friendlyfire 1
mp_freezetime 3
mp_fraglimit 0
mp_hostagepenalty 0
mp_limitteams 6
mp_logfile 1
mp_logmessages 1
mp_logdetail 3
mp_maxrounds 0
mp_playerid 0
mp_roundtime 3
mp_startmoney 800
mp_timelimit 35
mp_tkpunish 0
mp_winlimit 0
sv_aim 0
sv_airaccelerate 10
sv_airmove 1
sv_allowdownload 1
sv_clienttrace 1.0
sv_clipmode 0
sv_allowupload 1
sv_cheats 0
sv_gravity 800
sv_lan 1
sv_maxrate 7000
sv_maxspeed 320
sv_maxupdaterate 101
sys_ticrate 10000
decalfrequency 60
pausable 0
log on
decalfrequency 60
edgefriction 2
host_framerate 0
exec listip.cfg
exec banned.cfg
rcon_password <PASSWORD>
At <HOSTNAME> we can type anything we what example "Jack's Counter-Strike Server"
<PASSWORD> is the rcon password for the admin to the server it is used to remote control the
server.
Installing Admin Mod
We have downloaded earlyer halflife-admin-2.50.60-win.zip wich we will extract it anywere and
double click on install_admin.vbs after wich it will ask us where to install. You will se
diferent targets , we are interested in C:\HLDS so we type the number of the target, it will
ask us what mod to install we are interesated in cstrike. OK and that's about it.
Installing StatsMe
we downloaded statsme-2.8.3-cstrike.zip extract everything in C:\HLDS\cstrike
Go to C:\HLDS\cstrike\addons\metamod open plugins.ini with wordpad and here add the next line
on top of the existing one :
Code:
win32 addons\statsme\dlls\statsme_mm.dll
Go to C:\HLDS\cstrike\addons\statsme open statsme.cfg with wordpad
At sm_menupassword modify r3wt with an other password (it's a must! or something won't work)
to make de /rank and /top10 work
open the same statsme.cfg at sm_storebyauth put 0 instead of 1
How to start the server using less resources
make a shorcut for C:\HLDS\hlds.exe on the desktop
on the desktop click the properties of the shortcut you will se at the target C:\HLDS\hlds.exe
we will just add this line ( note ! leav a space between C:\HLDS\hlds.exe and the code)
Code:
-console -game cstrike +ip External IP +sv_lan 1 +maxplayers +map de_dust2 -nomaster
example of target:
C:\HLDS\hlds.exe -console -game cstrike +ip 69.69.123.231 +sv_lan 1 +maxplayers 22 +map
de_dust2 -nomaster
To start the server just double click the shortcut hlds.exe
This is the basic Dedicated Server with Admin Mod and StatME
