Vibration in spin cycle. I have replaced the shocks, tub seems to not be setting as firm as it used to.
If you have changed the shock absorbers and the washer still has a bad vibration in spin, the rear drum with bearing might need to be replaced. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, if this is the problem it is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Use the pump drain hose and gather in a container
I had same problem. It was actually wearing out the rubber gasket on front door. It ended up being the spider on back of drum. They corrode pretty good with the front loaders.
The spider will break if it vibrates that badly. Prevention is better than cure though.
The machine must be set up level. otherewise it will vibrate badly. Slide the machine away from where it stand, and using a long spirit level ( mine is 24 inches) findout which of the four feet is highest.. Screw in that foot fully. The measuring carefully ascertain the difference in level of the other feet. Adjust the feet accordingly and move the machine back in place. Verify that the machine now stands level
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
SOURCE: my washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
SOURCE: WM2487HRM goes thru the wash cycle then gives OE
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
SOURCE: Bad vibrations/shaking with LG washing machine WM2032HW
What's the exact model of your washing machine? I'll need this to get you exact part numbers.
If you're looking for a quick and cheap fix that works. Try installing a rubber anti-vibration pad under the washer. I've had the best luck with a pad called Silent Feet. They are pretty hard to find in stores but Amazon.com carries the full line of Silent Feet anti-vibration pads. They will provide you with the best results short of replacing the full shock isolation assembly in the washer. And they cost a lot less.
SOURCE: LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
