The message you are receiving is not actually an error, but rather your range has somehow been set in "sabbath" mode ( for the Jewish calendar I think...not the band, lol ) If you have the owners manual refer to the section referring to this an it should instruct how to reverse the setting.
All ranges do it somewhat differently. This example is generic, hopefully it works. If you are unsuccessful let me know and I'll see if I can locate it. Hold Clock pad for 5 seconds to activate Sabbath mode. HoldClock pad for 5 seconds to disable Sabbath mode. Oven must be in BAKE mode before enabling SABBATH. "SAb" displays and flashes for 5 seconds. All pad inputs are disabled except for CANCEL and CLOCK pads.
This mode disables the normal 12 hour shutoff to allow operation of the bake mode for a maximum of 72 hours. Good luck. Thank you for choosing FixYa. If this does resolve the issue, please take a moment to rate the assitance I provided as well as your experience here at FixYa.
Your range has somehow been set in "sabbath" mode ( for the Jewish calendar I think...not the metal band, lol ) If you have the owners manual turn to the section referring to this an it should instruct how to reverse the setting.
All ranges do it somewhat differently, so I can't say exactly how on yours. This example is generic, hopefully it works. If you are unsuccessful let me know the exact model number and I'll see if I can locate it. Hold Clock pad for 5 seconds to activate Sabbath mode. HoldClock pad for 5 seconds to disable Sabbath mode. Oven must be in BAKE mode before enabling SABBATH. "SAb" displays and flashes for 5 seconds. All pad inputs are disabled except for CANCEL and CLOCK pads.
There are two main reasons for not getting the heat. The prime reason is may be your reversible valve RV would have not activated. And also your setting temp must be +5 degree from your room temp. You will find a click sound in RV when you turn to heat mode. If within maximum of 5 minute if you dont't get it, call repairman.
press and hold the pound button then your screen will say exiting silent mode. and if you press and hold the pound button after that your screen will say silent mode activated
1 Press SOURCE and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
Language select appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
Switching the reverse mode
If you do not perform an operation within
about 30 seconds, screen indications start to
reverse, and then continue reversing every 10
seconds.
1 Use MULTI-CONTROL to select
Reverse mode.
2 Press MULTI-CONTROL to turn the reverse
mode on.
# To turn the reverse mode off, press
MULTI-CONTROL again.
Note
You can also turn on or off reverse mode by pressing
BAND while this unit is turned off.
Your deck has "reverse mode" activated. To turn it off, just turn off the power by holding the source button. The press the preset "5" button. When you turn the deck back on, reverse mode should be disabled.
(If this doesn't work, try the same procedure with button "6". One's for reverse mode, the other for demo mode, but I'm not sure I remember which is which).
