Question about Vizio E322ar
Vizio e322ar wifi problems
I keep putting in the right wifi code and it keeps saying could not connect.
2 Suggested Answers
6ya staff
SOURCE:
rgall3285
ray gallant
  • 65367 Answers
SOURCE: My vizio E322AR will not power on. What happened?
Died of course .
Posted on Oct 04, 2015
Hi, I have a Vizio 32" smart t.v. Model # E322AR and it doesn't work. It won't turn on anymore.
U have a sick puppy there. U might want to check the power supply of unit since it is usually one of the primary areas that go on these products.
Aug 19, 2015 | Vizio Televison & Video
How do I get it on my wifi network? it keeps telling me it is avoiding the network because of poor internet cinnection.
If you have poor internet connection problem with your WiFi, try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from ScanmySpeed.com before and after following these steps.
Dec 25, 2014 | Tablets & eReaders
What can I do? I have a Vizio Smart TV 32 in model # E322AR. When I turn it on it shows 2 screens in black and white. When I hit the menu button it shows it in 4 rows going down and 3 rows across. And
your problem is most likely due to a faulty t-con or main board. The good news is that research shows that your t-con and main board are all in one. Vizio's are known for bad main boards. The question is it worth repairing? The good board from a reputable company will cost $80 plus, the prices on 32" sets are below $200 in some markets nowadays. If I have been helpful please sign my guestbook!
http://www.back2lifeelectronics.com/Guestbook.php
Jun 10, 2014 | Vizio E322ar - 32 Class 31.5 Viewable Lcd...
Vizio e322ar won't turn on
My Vizio E322AR White Vizio Light comes on when plugged in, then slowly fades to "Off". I unplugged and replugged - same. I held down the power botton on the side, and plugged in... same. Vizio light comes on (White) and over 5 seconds or so... fades out to nothing.
Remote doesn't do anything, buttons on the side don't do anything.
Going to pull the back off and look for bad Capacitors, and test fuzes for continuity. Wish me luck ... will report back later with results.
Feb 21, 2014 | Vizio E322ar
Connects to wifi but wont respond
Have you entered the router code?
Dec 25, 2013 | Gateway NV5207u Notebook
My wifi keep saying disconnected this phone is not on I just let my son use the phone to download apps I reseted everything because it was not working right yesterday and now i can't get the wifi back
try this solution...
1. select "airplane mode" to disable all wireless connection then turn off your phone.
2. turn on your phone then disable "airplane mode"
3. turn on your wifi now.
Mar 05, 2013 | Cell Phones
Can i use a westinghouse screen to replace a vizio screen
Kenneth,
Please re-post in Electronics > Televisions & Video
The only thing I can state, is look at the manufacturer code on the back if the screen, (Westinghouse), and see if it is a replacement for the Vizio's screen.
[This is the Laptop PC category]
Regards,
joecoolvette
Feb 25, 2013 | Vizio 32" Class LCD 720p 60Hz HDTV with...
The Netflix app on my vizio svt422xvt (one of the Vizios with VIA internet & wifi built-in) won't connect to Netflix. It directs me to the Netflix website for help, but Netflix help tells me to...
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
Aug 11, 2010 | Televison & Video
How do i keep wifi switched on permanently
Hi:
Well you have to click on start in the bottom left hand corner of your PC. Than on the right there is a button that says "Connect to". Click on it. Then press View Wireless Connections. When your done just press on your optimum wifi/comcast wifi.
- For any questions email me at... xoiceybabe21@aol.com
Thanks,
Nikki
Nov 04, 2009 | Computers & Internet
Vizio E322ar Logo
102 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
