Nothing more to add. thanks
SOURCE: mitsubishi wd-62725 rear proj green timer light will not reset
you need the V26 DLP DM repair kit at the following link. The kit contains the replacement capacitors and the cd with instructions.
http://www.tvrepairworld.com/
SOURCE: my mitsubishi wd-62528 has a constant rapid green
Thats a common problem most likley caused by failed capacitors on the DM and the power board. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which contains the capacitors and the CD with instructions for the repair.
SOURCE: When I replace the lamp in my wd 60735 is there a
As soon as the set is powered up after replaceing the lamp. The set should bring up the screen that asks if you have replaced the lamp. Just select yes and that resets the lamp life.
Testimonial: "thank you I didn't get that screen ???? on my TV"
SOURCE: I am trying to replace
The thermal sensor is located on the lamp cartridge housing. here take a look at this link
http://www.keepandshare.com/doc/1864328/wd-series-lamp-temp-service-bulletin-vs72-pdf-april-18-2010-6-50-pm-1-0-meg?dn=y
