Televison & Video Logo
Posted on Oct 31, 2007
SYSTEMLINK 3 RCA UNIVERSAL REMOTE CODE 4 A MAGNOVOX TV
HAVE NO CODE BOOK AND WOULD LIKE TO PROGRAM MY TV.
  • 2 more comments
  • jaxbak Dec 31, 2007
    have no designated "code search" button
  • Anonymous Nov 22, 2008
    i c
    ok have sylvania tv and one of these remotes it will let me program the tv to change the cannels and volume but wont let me switch the t.v./vidieo to watch dvds or play vidieo games i dont know how to fix this can u help me?
  • Anonymous Mar 14, 2014
    Having trouble program sears tv from 2001 with this type of remote
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 27, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3400
Points
13
1 Related Answer
A
Anonymous
  • Posted on Sep 15, 2008
SOURCE: SYSTEMLINK 3 RCA UNIVERSAL REMOTE CODE 4 A MAGNOVOX TV
tengo un tv sharp y no tengo el codigo universal
Re: need codes for rca remote Systemlink 3 for 22729 tv
Katina, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.remotecodelist.com/remotes/rca/rca_systemlink_prog.html
RCA universal remote code lists RCU Series Systemlink series direcTutor
Electro help RCA SYSTEMLINK 3 UNIVERSAL REMOTE TV SETUP CODE LIST SETUP...
WHATS THE CODE FOR RCA TV ..I HAVE A ONE FOR ALL UNIVERSAL REMOTE NEED THE CODES TO PROGRAM MY RCA TV
You received a list of ALL Codes with your universal.
I got this off the internet. But I do not know what type of universal you bought. You didn't mention it.
Good Luck.
Here is the link if you need it. :0)
http://www.google.com/search?q=universal+code+for+rca+tv&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
rca
1helpful
Need code # for rca tv
If your remote control has a search button, this is how you do it-------- User submitted information for the SystemLink 3: To clear things up and make it simple, here is how to program the RCA Systemlink 3 remote:
****WITH DEVICE TURNED ON****
  1. Press and hold the "Code Search" button until the LED lights, then release. LED will stay light.
  2. Press and release the device key to be programmed. LED will go off when button is pressed and back on when released. LED remains on.
  3. Press and release the remote On/Off (power) button as many times as required to turn your device OFF.
  4. When device turns OFF, press and release the ENTER button.
Test remote on device, if ALL functions do not work, repeat above procedure.
***IMPORTANT NOTE*** Count how many times you press the On/Off button. If ALL funtions do not work and you need to repeat, you don't want to stop at the same non-working code. For instance, if it takes 23 times to turn your device off and after testing, the remote does not control all functions, repeat steps 1-3 BUT when the device turns off at the 23rd time, turn it back on using the power button ON THE ACTUAL DEVICE then continue with step 3 and 4 from above.
My RCA450 universal remote control does not have a code search button
the rca systemlink 4 remote is very good.it has code search and menue
try also the menue button on the tv itself
1helpful
5helpful
2answers
Universal remote codes
I found the following web site which lists the codes for the RCA SystemLink 4 RCU400C universal remote.  It's http://www.thompsontv.com/rcarc.html.
39helpful
16answers
MY TV IS SANKEY AND I CAN`T FOUND THE CODE IN THE LIST OF MY SYSTEMLINK3 RCA, Please i need help! Thank`s
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
