Hoover Max Extract 77 Multi-Surface Pro Carpet & Hard Floor Deep Cl Logo
A
Amanda Posted on Mar 30, 2014
Hoover max extract 77 wont pick up water
It wont pick up water at all. ive tried to disassemble the thing to clean the brushes and cleaned the filter and nothing works please help
jennie casch
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 03, 2014
jennie casch
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2650
Points
5
Did you make sure the dirty water tank is cleaned out and the cap is on?also did u check the clear kinda hour glass shaped thing in the front where the water sucks up at to make sure there is no blockadge?
Why doesn't the water pick up on my carpet shampooer???
Hi Julie! If the cleaner is not picking up the dirty water this usually means something is not sealed off properly. Try these steps below to restore suction to your cleaner.
1. Remove the clean water tank. Recline the handle & let the handle lie down on the floor.
2. Remove the dirty water tank. Check that the dirty water tank cap is on the dirty water tank and tightened closed.
3. Clear the filter screen of any hair or debris.
4. Remove the nozzle. Clean the nozzle of any hair or debris.
5. Located on the machine behind the nozzle is a 2nd filter screen. Clean it of any hair or debris.
6. Replace the nozzle.
7. Replace the dirty water tank. Press down on all sides so that it is flush to the cleaner base.
Give it a try! The suction should be restored to your cleaner. If not I have included a video link where you may view these instructions. Hope this helps! Loss of Suction Won pick up Hoover Max Extract 77 FH50230 FH50222...
How to use the upholstery attachment for hoover max extra 60 carpet cleaner?
Hey there! The nozzle/valve that releases the solution from the hose may be clogged and not closing off to stop the solution flow. You can try soaking the trigger end in warm water for a few hours to unclog it. Also make sure you are inserting the hose back into the hose slot in the back of the cleaner. If the cleaner is still dispensing from both the hose and the cleaner, your nozzle/valve assembly may need to be replaced. To order a replacement nozzle/valve assembly follow the link below.
Search Results
Hope this helps!
1helpful
How to remove nozzle for cleaning
Hi! We made the nozzle assembly easily removable for the Max Extract Dual V. Follow these quick steps.
Remove both tanks from the cleaner.
Lay the cleaner on its back while in the upright position.
Lift up rear edge of nozzle. Slide nozzle up and remove from cleaner.
I have also attached a copy of the owner's manual which has pictures if you need it. http://hoover.com/file/1088/
Hope this helps!!
Why is my clean tank emptying immediately to my dirty water tank?
Hi Medori! It sounds like you have an issue with your pump assembly. We recommend taking your unit in to a Hoover authorized service center. For your convenience I have included a link to our service center locator. Hope this helps!
Service Center Locator
Why does my hoover max extract leak water onto the floor?
seals faulty, replace or shop replacement if within guarantee
How do I clean cat hair out of spin brissels
Hey there! The brushes can be removed for cleaning. With the handle in the upright position, tilt the cleaner back so that handle rests on floor. Grab brush assembly and pull firmly. Remove hair and debris from brushes. You may clean the brushes under running water. If for some reason you are not able to clean the brushes, replacement brushes can be ordered by following the link below.
Search Results
How do I fix pin at bottom of clean water tank?
Replace the part. This might mean buying a whole new water tank. You can order most parts online. Have your make and model ready. Find a site by google. ie if it's a hoover enter, "hoover parts".
Hoover max extract widepath won't spray water
One of your two water Inlet valves (either Hot or Cold) is not working and need to be replaced
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
My max extract is making a whiring sound and i can smell rubber burning
The beater brush is binding in a locked up state. Probably by hair and carpet fibers. Dis-assemble and clean out any debris and change the belt/
Top Hoover Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Hoover Air Purifier Expert? Answer questions, earn points and help others
