Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
Posted on Nov 05, 2017
Door Handle - Screw coming out
June 15, 2009
On the right hand door the top screw holding the handle to the door is coming out and appears no way to get at it to tighten it up. The cap between the inner part of the handle and the door is now about on-eights of a inch and not sure how many threads of the screw are still remaining.
thanks
wricklee
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Nov 05, 2017
wricklee
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
Helped
2652
Points
25
Not quite sure about your problem but, if it is a wood screw going into your door, you can take the screw out a insert a hardwood toothpick into the screw hole and reinstall the screw. this will fill any stripped out of the hole and screw should fit securely. If it is a metal to metal problem you can go to the hardware store or even walmart and buy a product called " Locktight". it is a liquid that you put on the screw and reinstall it. it will dry and lock the screw in place. Buy the blue if you want to eventually take it out at some point or buy the red, if you want it to stay in place and take a lot of effort to get it back out.
5 Related Answers
A
Anonymous
  • Posted on Dec 30, 2007
SOURCE: refridgerator door handle
some there is a plastic sleve or cap you push up to get to it some you open the door and pull back on the gasket to get to hard to know without mod num
A
Anonymous
  • Posted on Apr 09, 2008
SOURCE: Ge profile refrigerator door handle is loose
On the GE Profile, the handle is mounted to two small screws. To detach the plastic housing, you must press on the two connection points (the base and top of the handles) and slide the handle up or down (takes some effort). The handle will come off and you will have very easy access to these 10mm screws.
geapptech
  • 157 Answers
  • Posted on Feb 17, 2010
SOURCE: My freezer door handle is coming loose. How do I
The handle should slide to the left using the handle release card
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Oct 31, 2011
SOURCE: side by side refrigerator, handle
Hello, mark
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about refrigerator and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-refrigerator.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Anonymous
  • Posted on Aug 15, 2012
SOURCE: handle on bottom freezer door
Thanks to Dana; it was a 5-star screwdriver, which I was fortunate to find one in my collection of tools and solve the problem. 30 minutes to figure out it was a 5-star screwdriver and find the tool; 3 minutes to fix the handle!
Lg Gn422s loose handle, I can't see a screw to remove the plastic handle at all
You will need to remove the door seal and expose the screws that hold on the inside plastic door trim
remove the door trim to get to the handle screws
2answers
I have a new door to replace the right side one on this refrigerator but for the life of me I can't get the door handle off the old one. New one didn't come w/ the handles/hinges, etc, obviously. The...
Are you sure...
To move refrigerator through a house door, it may be necessary to remove the refrigerator door handles.
NOTE: Handle appearance may vary from illustrations on this page.
1. Removing Refrigerator Handle
ā€¢ Grasp the handle tightly with both hands and slide the handle up (1)(this may require some force).
ā€¢ The keyhole slots (2) on the back of the handle allow the handle to separate from the mounting screws (3).
CAUTION: The handle could be damaged if you hit it with a hammer while removing or attaching.
CAUTION: When you assemble or disassemble handle, you must push or pull with reasonable force.
How can I change the mirror control panel?
Firstly, get a replacement switch. Carefully take off the cover of the door handle (mine is the diagonal kind - 2002) and then unscrew the two screws at the top and bottom of the handle. Then Unscrew three screws at the very bottom of the door panel - they are the "star" kind - a tork screw. Carefully pull out the snaps on the sides of the door panel. They just pop out of holes in the door frame. Be carefull not to pull too fast or suddenly. Then pull straight up on the door panel. It can be very sticky at the top but gently work it out of the rubber slot at the top. OPTIONAL: Now that the panel is free, disconnect the electrical and door pull cables. Make a note of what connected where! You can skip this step if you can do the next step in a tight spot... You'll see the assembly for the door handle, lock, and mirror switch. There is a screw by the door handle. Unscrew that, then carefully pry open the clips that hold the assembly in. The whole assembly will come forward out of the door panel. Now, carefully unclip the mirror switch. It will come forward out of the assembly. Place the new switch back in its place, and re-clip. AT THIS STAGE, RE-CONNECT THE ELECTRICAL WIRE TO THE SWITCH AND TEST! Replace the assembly back in the door panel. Replace the screw by the door handle and re-connect the wires and cables. Then "Hook" the top of the door panel on the rubber slot. You can check the other door to make sure it's right. Carefully snap back in the sides of the door panel then reconnect the three screws at the bottom. Finally, replace the two screws in the door handle, and replace the door handle cover.
Best of luck
1helpful
Driver side door handle (outside) and gas pedal 2000 Camry
Bring the vehicle into the dealer if you have a sticky gas pedal. This is a TOYOTA PROBLEM.
Door handle:
It easy ! You need a philips2_bing.gif and flat screw driver,and a needle nose pliar.
Use flat screw driver and pry out the two or three dust covers for the arm rest screws then use philips and remove the screws. Next use the flat screw driver and pry out the black plastic mirror cover from the inside of the door. Pry out the switch with the flat screw driver and disconnect it. On the side of the door panel just above the striker/loch mechanism is this plastic push pull type of a hold in screw. Use flat screw driver to get it to move a little then pull it out with the needle nose. Depending on which door your doing if you have a map folder in the door there are two more screw to remove on the bottom of the door.
Now the inside door handle is tricky it comes out in TWO pieces. Use philips and get the only hold down screw you see out.( you may have to pry out a little screw cover first) Now the inside door handle cover is removed by placeing the flat screw driver on the rear of the outside of the cover top and on the outside rear bottom to release the tangs that are holding it onto the panel.Pry it out lightly you may have to place the screw driver over the top of the door release button and pry that way. Don't loose your cool its a pain but it will fall out. Once its removed unhook the panel.
Next lift the plastic cover and remove the door handle hooks and levers . Basically use common sense this is easy stuff. There may be two screws from inside of door panel that keep handle in place . Then work handle loose from outside and inside . reverse for installation.
2helpful
I need to remove and change to the other side the GE GDL20KCSABS refrigerator door handle. The manual is unclear and there is no screw visible at all and trying to slide the handle up off the mounting is...
The handle does slide up off of the handle bracket where a screw will be visible . Remove the screws and on the other side of the door , remove the faceplate for the top screw and the plug for the bottom screw . These should pop back in the screw holes from where the handle was . If you do not see a small hex screw close to the top of the handle and bottom , then yes , the handle will pop upwards to remove . Dont try by just lifting , pop upwards with your hand or rubber mallet . Remember , these handles were made to be tight on the doors to last a long time without comeing loose .
2helpful
2answers
How do I remove a door panel on a Suzuki Aerio
The top of the grab handle pops off and there are two screws underneath as MrEcko wrote. Remove the one screw from the door opener handle and slide the handle and trim forward about 3/8 inch. It will then come out and you can remove the control rod.
15helpful
Need to know how to install exterior door handles
I'm assuming that you have the coupe not convertible since I've had same problem with my 97 Dodge Avenger and this is quite common from what I have heard. The handle is held in place by two 10mm bolts. One is easily accessable, located right beside the handle with the door open. The other is a little harder to get at. The first thing you need to do is remove the inside door cover, held in place by four screws and push in clips along the bottom that pull out easily. Two of the screws are visible and in the top corners of the door panel. One screw is located behind the inside handle and once removed the moulding comes off quite easily. The other screw is in the hand hold where you pull the door closed and has a small plastic cover over it. If you have power windows you are able to disconnect the switches once the panel is off. If manual windows, the handles are usually held on by a clip that can be pushed off with a screw driver allowing you to pull of the crank handle. The window needs to be in the closed position so you can access the ONE 10mm bolt holding the outer door handle. Once the interior door panel is off, if any clips remain in the door, take them out and put them where they should be in the door cover it won't go back together properly if you don't. Now you'll need to pull down the corner of the plastic covering the door, don't remove all the plastic just enough to allow access to the bolt. I used a small rachet to get it out. It is in a stupid spot with not much room but is doable. Once out, the handle is only being held by the lock rods to the handle and lock cylinder. The lock cylinder is held by a retaining clip which can be slid off allowing the cylinder to be pushed out. The other rod connected to the handle has a plastic clip on it holding it in place. This can be opened with a small screwdriver. Once opened the rod will come out easily and the handle should come off the door. The only problem reinstalling, that I had, was reconnecting the rod to the handle and found that if you unscrew the door latch, the whole mechanism can be moved down, giving you more freedom to work with the rod. You might want to do this before fighting with the clip holding the rod in place, just a thought as I got mine apart in 20 min. Installing the new handle is quite easy, just attach rod to the handle FIRST before anything else. Once the handle is back on the door the lock cylinder can be pushed back in, it just gets in the way if you put it in the handle right away. Hope this is of some help.
6helpful
2answers
Kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
