Question about Buffalo Tools Sportsman Series 4000 Watt Portable Gas Powered Generator Gen4065
Have a 4000 watt sportsman generator that will not produce electric i have replaced the avr what next
Engine starts and runs fine was working and the next time I went to use it it would not produce electric
    New Friend:
  • 4 Answers
Could be lost exciter current. This is how to restore it - Connect 16 or 18 gauge wires to a 12 volt battery. With generator running, insert bare ends of wires into AC outlet - one to Hot, the other to Neutral. Insert and remove quickly. There should be a flash and power will be restored. If not, repeat until you get that flash and output current restored. Using light gauge wires is so that if you are too slow to remove them once AC is restored. they will burn out before the battery suffers from the AC incoming. Be quick and be careful.
Posted on Apr 14, 2014
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: I have a 4000 watt Coleman generator that won't
If it has been in storage with gas in it. it is gunked up. Need to remove carburetor and take to someone to clean carb.
Posted on Aug 23, 2009
GetMeOttaHere
  • 2926 Answers
SOURCE: 4000 watt buffalo tools generator: Engine
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Posted on Feb 05, 2010
Honda GXV160 will not start.
Is it getting spark? Have change spark plug?
Aug 28, 2017 | Honda Garden
Starts fine, run fine,for about 2 to 5 min.,then cuts off,sounds like it's not getting the gas.
I have a Husqvarna 125B same problem. Turned out to be a bad gas cap. Doesn't vent properly and starves the engine. I took the gas cap off of my Huqvarna weed eater and put on blower and blower worked fine,
Nov 11, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Starts fine...no juice....sat for 10 years in the box...started using it 3 weeks ago...worked fine until yesterday....starts...runs..no juice...no circuit breakers blown...what's up?
Colemans were known for losing what is known as "residual magnetism", especially when sitting for long periods of time without use. This residual magnetism is necessary for exciting the field to produce electricity. Here is what you can try: Plug a 110v drill into one of the 110 outlets. While the engine/generator is running, with an open hand (not fingers wrapped around it) spin the chuck while holding the drill trigger in the run position. Many times this small amount of current that will be produced by spinning the drill motor will restore the residual magnetism and excite the field. Keep in mind that if this works, the drill motor will begin to spin immediately since it is plugged into the outlet. Hope this helps.
Mar 04, 2011 | Coleman Powermate Powermate 5000W...
The engine was starting and running fine but when I went to start next time engine backfires through exhaust and carbies and will not start
better check ur jets manlly air jets souns clogged up you might be getting bypass in pilot jets too easy fix
Feb 23, 2010 | 1996 Honda CBR 250 RR
Coleman 5500 W/Yamaha MZ300 engine, runs great, no power produced
next is...brushes..
if they were fine check AVR
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Aug 29, 2009 | Coleman Powermate Premium Plus 6250W...
Car starts, then doesn't, then does, then doesn't
check the fuel pump relay! It sounds like it is one of your relays. If it was an electrical or sensor problem, the check engine light would be on.
May 22, 2009 | 1998 Mercury Grand Marquis
My 1997 Dodge Avenger's engine won't start
Try cam and/or crank sensor. If crank to cam timing isn't detected properly it'll crank all day but won't start. I had similar problem on my 2.5L V6 Avenger....drove home fine, no engine light, next morning it cranked, but wouldn't start. The crank sensor was faulty.
Jan 11, 2009 | 1997 Dodge Avenger
Doesnt always start, but lights, radio, AC/heat does come on.
First place to check is the battery. Old ones can push your lights , radio, etc, but the starter is the real load. . Can verify this by using jumper cables to a running vehicle and watch your machine fire right up! The reason mornings are the worst, is the battery has had the most time to discharge, and it is probably cooler outside.
Dec 23, 2008 | 2000 Oldsmobile Intrigue
My 1989 Pontiac Trans Am has a 305 Tune Port Injection engine that won't start. There is spark in all electrical components, fuel pressure but still won't start. We have replaced the computer and still...
Come to find out after spending $560.00 on electric parts that were not needed, the number 5 fuel injector was shorting out causing the engine not to start. It would turn over but wouldn't catch. I unplugged the injector and it started right up. I let it run for a bit and while running, plugged it back in and sure enough, the engine stalled. This particular engine had us going crazy. We thought if an injector went bad at least have the engine would run. Apparently this one has a safety mechanism on it so half the engine won't warp for working while the other half don't. The injector will be replaced very soon and will be back in perfect running condition.
Jul 16, 2008 | 2002 Pontiac Firebird
Buffalo Tools Sportsman Series 4000 Watt Portable Gas Powered Generator Gen4065 Logo
1,627 people viewed this question
Top Buffalo Tools Electrical Supplies Experts
Lawrence Oravetz
wadingriver
wadingriver
Bill Boyd
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
