My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
Good day, after i tried to program my universal remote control, my Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black. I have sound, but no picture just solid colors switching. Cannot use remote and buttons on tv not working either. Could you please help me with this matter? Thanks
Re: My Proscan led TV (PLDED3273A) is switching color...
Just do a hard reset to this set and check. To make it a hard reset, unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If this do not help you, the main board to your TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1992 Honda Civic
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1992
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White Switched 12V+: Yellow/Red Ground: Black Illumination: Red/Black Dimmer: n/a Antenna: Driver's Pillar
Front Speakers: Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black
Rear Speakers: Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a Metra Brand Wiring Harness: 70-1720 Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness Starter: Black/White - Ignition Switch Harness Ignition: Black/Yellow - Ignition Switch Harness Accessory: Yellow - Ignition Switch Harness Tach: Blue - Distributor Brake Switch: Green/White - Brake Switch Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector) Parking Lights: Red/Black - (+) Above Fus Panel (White Connector) Head Lamp: Red/White - Steering Column Hood Pin: n/a Factory Disarm: Disarms with Unlock Door Trigger: Green/Red - (-) Driver's Running board Door Lock: Green/White - (-) Driver's Door at Door Lock Module Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module Horn: Blue/Red - Steering Column (Relay Required) Windows UP: LF=Red/Blue RF=Blue/Yellow Windows DOWN: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake Switched 12V+: Black/Yellow - Ignition Switch Harness Ground: Use Chassis Near Cruise Control Module Hot Side of Brake: n/a - Brake Switch Cold Side of Brake: Green/White - Brake Switch Tach: Blue - Distributor VSS Wire : Yellow/Red - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
Place your phone on picture mode. place it over the remote infra red section the press any button on the remote. If you see a red signal then the remote is good. If not, you need a new remote.
If the remote is good then your sensor on your t.v. is bad. You will need it replaced.
hi,
I think some how you have gone into service mode on the tv.
you may need to take it into a repair shop so the can re-set it back.
sounds like it to me.
hope this helps
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
