SOURCE: ea ssports cricket 07
dear friend .
you need to insert the cd for cricket 2007.
(it may be two cd pack)
insert the cd1 then autoplay starts .
and starts installing if it does not start automatically.
double-click on your cd/dvd drive.
after it starts it asks for key which u can get from
crack folder and right click on rid07 aand run as .
it generates the key which then can be used for the installation.
after that it asks for cd2 insert it and finish installing .
for playing u need to copy all files form crack folder.and paste them in your EAgames/cricket07 and replace existing file.them u can play the game.
thanks for reading the solution.
SOURCE: what is code for EA sports cricket 2007 to instal
8Y3K-VWZZ-FU45-AFUU-8RLD 2H22-U4PD-MDWS-EMDN-WRLD
SOURCE: i install ea cricket 2005
u can play the cricket 2005 on windows 7 by following these steps
1. right click on the setup file of Cricket 2005 and select properties
2. select the tab Compatibility and you have to select the option which says" Run this program for compatible mode for" and select Windows Xp Service Pack 2 and click on apply button .
3. Then install the game
