you are having trouble resetting your Nextbook 8P. Here are a few steps you can try to reset your device:
- Soft Reset: Hold down the Power button until the device turns off, then turn it back on.
- Factory Reset using the Settings: Go to "Settings," then "Backup & reset," and finally "Factory data reset." Confirm the action and wait for the reset to complete.
- Factory Reset using Hardware Buttons: If you are unable to access the settings menu, you can try resetting the device using hardware buttons. To do this, you will need to follow these steps:
- Power off the device
- Press and hold the Volume Up button and the Power button
- Release the buttons when the Nextbook logo appears
- Press the Volume Down button to navigate to "wipe data/factory reset" and press the Power button to select it
- Confirm the action by pressing the Volume Down button to select "Yes" and the Power button to confirm.
If none of these steps work, the device may have a hardware issue and it may be necessary to contact the manufacturer or a professional repair service for further assistance.
