I have a similar problem. am using Cox Cable RI, expanded basic service.
used to get some digital content prior to the DTV cutover, but sometime prior to that, my VX37L continued to detect the digital channels when using autosearch, but didn't render the picture when tuned to the channel it found.
it does get digital signals over the air, with an outdoor antenna.
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
SOURCE: Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
SOURCE: Sudden no signal on digital channels on a Vizio VX37L
That may not be correct. You would not lose all your digital channels. Vizio has an un-addressed problem with losing digital stations. Multiple threads are posted due to this problem, which is why I am on this site. I have lost all digital stations on CATV connection. The Toshiba set in the next room is getting over 150 DTV channels, the Vizio, only analog. Zero Digital.
